Question about Vizio Televison & Video
I have a Vizio D55U-D1 LED TV. I power it up and everything works fine for a few minutes. Then the screen locks up but the sound still work. After a couple more minutes it power cycles.
Posted by David Tafoya on
    Top Expert:
  • Vizio Master
  • 76,625 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Posted on Mar 08, 2020
1 Related Answer
gopakumarg43
  • 76625 Answers
SOURCE:
Flickering can be adjusted. Contact any experienced service technician. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Nov 10, 2017
Vizio d55u-d1 power light comes on then fades off. No sound or picture. Replaced power supply board, nothing still.
Chances are you have a main board issue, you should have run some voltage tests before replacing the power board, its sad how many people order boards that aren't bad because they don't do the necessary testing prior to ordering boards.
Just got a Vizio D55u-d1 LED tv, every couple minutes or so I get these white flickers as seen in the photo. They last a second and go away. It happens all over the screen. I've tried the following 1....
1helpful
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
I have a 55' Vizio Tru LED model VF552XVT. The TV ran fine for a year and a half and just recently the screen started shutting off after a few hours. I am aware that there is an issue where Vizio
It sounds like an overheating issue with the T-con board. You shouldn't have to run a house fan behind the TV to keep the screen on. Make sure you have the TV in a place where there is enough space around it to allow for air flow. Also, check to make sure the ventilation slots on the back of the TV are not blocked with dust.
1helpful
2answers
Vizio GV47L not turning on after a pop noise
check your power board, most likely that's the part that is causing the problem.
Televison & Video Logo
Top Vizio Televison & Video Experts
Paul Bade
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
