Is screen printing easy? - Office Equipment & Supplies
Posted by David C Harris on
Frank Bell
    Habit-Forming:
    Scholar:
  • 25 Answers
The actual process of screen printing isn't technically difficult. The most difficult part is creating your print designs and acquiring all the equipment that you need to do screen printing.
I first started screen printing a few years ago as I wanted to make t-shirts for selling on Etsy. I watched a ton of YouTube videos on what to do and what equipment I needed to get started. After that, I searched the internet to find a reasonably priced supplier of screen printing consumables.
Once I had all my equipment, screen printing actually became quite easy. However, if you're not really sure where to start, I would definitely recommend watching some YouTube videos about screen printing before you invest in the equipment as it can cost quite a lot to get all of the supplies. What I will say is that screen printing is really fun and you should definitely try it if you haven't before.
Posted on Feb 15, 2020
Camera works fine until i plug it into the printer, at that moment the LCD screen goes off and wont come on again so i can't print any pictures
Normally there is a kodak software you run on the PC and it show you the pics from the camera. Your trying to print directly to the printer without a PC? If so then you would use the printer menu.
UPDATE: Found the 310 user manual online from the Kodak site.
http://resources.kodak.com/support/shtml/en/manuals/urg00431/urg00431c3s3.shtml
4answers
Kodak easy share series 3 , only prints lower portion of picture.
Try reinstalling the printer driver. If that doesnt help, try a hard reset: Unplug the printer from AC power and PC, wait about 10 minutes and retry.
You can also do an alignment test. If none of this proves succesful, you either have a bad print head, or problem in the circuitry, which will need servicing.
I am reading a book on my new Aura Kobo ereader, the print is too small, how do I get back to menu to change size of print?
No menu required. Just use two fingers on the screen and slide them apart. Be careful, it's easy to get very big, very quickly.
To get smaller slide two fingers together on the screen.
2helpful
4answers
Why I can't take print screen on my notebook?
Have you tried the windows snipping tool?
3helpful
2answers
Dymo Letratag LCD screen not working
not easy to fix its dirty contacts on the lcd
can be cleaned an reassembled but not worth it unless your techy nerd like me.
2answers
When I press the PrtScrn button nothing happens. I can not find a way to print the screen
To do a "Print Screen, hold down the Shift Key and Hit PritScrn. Open Paint or some other graphics program and paste the image. This will paste the print screen to the graphics program and you can then edit, print or manage the print screen any way you desire. Let me know if you require additional assistance.
1helpful
How can I print off one frame in a video file?
it is a very easy task. play your movie with your favorite player on full screen when you find the right frame pause your player then hit print screen on keyboard. assuming tyhat you are using windows go to paint and press ctrl +V that would show your selected frame. hope this helps
19helpful
5answers
Print screen button does not work
I had the same problem and found out that I had to press the "F Lock" key first. I have no idea what F Lock is or who ever pushed it...but now print screen works the way I was accustomed to. Go Figure
I want to connect via a bluetooth bu20 a canon pixma mp610 printer to a playstation 3. the ps3 recognizes the printer but will not rgister the passcode. I am caught between sony and canon. can you help.
Issue: How do I access / change the bluetooth settings on the printer?
Solution: Change the machine settings (MP610)
Change the machine settings Instructions to change the settings on the machine. Displaying each setting screen
  1. Press the <HOME> (A) button.
  2. Use the Easy-Scroll Wheel (B) or the right / left arrow to select [Settings], then press the <OK> button.
  3. Use the Easy-Scroll Wheel (B) or the right / left arrow to select [Device settings], then press the <OK> button.
  4. Use the Easy-Scroll Wheel (B) or the up / down arrow to select the item to set, then press the <OK> button.
    < 1 > Print settings
    < 2 > Wireless print settings
    < 3 > Bluetooth settings
    < 4 > PictBridge settings
    < 5 > Other settings
    < 6 > Language selection
    < 7 > Reset setting
  5. Use the Easy-Scroll Wheel (B) or the up / down arrow to select the applicable one from the list, then press the <OK> button.
Print settings
< 1 > Prevent paper abrasion
Use this setting only if the print surface becomes smudged.
Note: When continuing to print with this setting, excess ink may smear inside the machine. After printing is completed, return this setting to OFF.
< 2 > Extended copy amount
Select the amount of image that extends off the paper when printing in borderless.
Note: When setting LARGE, more amount of the edges of an image is reduced.
Printing my network settings
When you have the settings on your screen. Hold the Ctrl key down on the keyboard & press the Print screen key on the keyboard at the same time. Open windows paint program. Click edit & than past. Now you can save the image as a .bmp file. Name it as you like. (This is called a work around).
Tom Chichester
