Question about Radio Communications
I can not put the bluetooth on, what now, stays on the off position
I cant get my ipod touch 4 to send Bluetooth pictures connect to Bluetooth or stay on Bluetooth what do I do???
Ipod needs to be put into discovery mode as well as the device that you are trying to connect to. Just turning on Bluetooth in the Ipod is not enopugh to get a connection. The two devices and any other devices that you want to connect to need to "Find" each other. Once that is done you should have no further problems.
Aug 19, 2014 | Audio Players & Recorders
Microsoft bluetooth mobile keyboard 6000
Wireless keyboards connect to tablets using Bluetooth, a wireless technology with a short range of only about 30 feet.
In most cases, you can prepare a keyboard to connect with a tablet simply by turning the keyboard off, then turning it on again while it is close to the tablet.
Read the instructions that came with the keyboard to see if it requires a passkey to connect with a device.
The passkey ensures that your keyboard is not accidentally connected to another nearby device. The steps required to connect a tablet to a wireless keyboard can vary slightly depending on the tablet's operating system.
Unlike docked keyboards, a wireless keyboard does not have to be designed for your specific tablet for it to be usable.
Turn on the keyboard and put it in discovery mode.
Place it near the iPad.
Tap the "Settings" icon, then tap "General."
Tap "Bluetooth" if it is in the Off position.
Tap the "On/Off" switch to turn it on.
Choose the wireless keyboard when it appears on the screen. Enter a passkey for the keyboard if prompted.
The keyboard name and a Bluetooth icon appear on the screen.
BlackBerry PlayBook Tablet
Turn on the Bluetooth keyboard and put it in discovery mode before placing it near the tablet.
Tap the "Settings" icon on the tablet status bar, then tap "Bluetooth."
Tap the "Bluetooth" switch to choose the "On" position.
Tap "Add New Device," then select "Search."
Wait a few seconds for the keyboard to appear.
Enter the keyboard passkey if prompted.
Samsung Galaxy Tab (Android)
Turn on the wireless keyboard and put it in discovery mode.
Place it near the tablet.
Navigate to the Home screen. Press the "Menu Key," then select "Settings."
Tap "Wireless and Network," then "Bluetooth Settings."
Tap "Bluetooth" to turn it on, then tap "Scan Devices."
Select the keyboard by tapping it.
Enter the passkey if prompted.
HP Slate (Windows)
Turn on the wireless keyboard while it is near the tablet, then put it in discovery mode.
Tap the Start button, then "All Programs."
Tap "HP," then "HP Connection Manager."
The device searches for nearby devices and lists them.
Locate the keyboard in the list, then tap the "Power Button" beside the keyboard entry.
Enter a passkey if prompted.
http://bluetooth.org/
Jun 29, 2013 | Microsoft Bluetooth Mobile Keyboard 6000
I am having trouble getting my 6230i to pick up my bluetooth headset.
you have to put the Bluetooth in pairing Mode and put the Phone in Discovery Mode also.
to put your bluetooth in discovery Mode - press and hold the middle button for about ten Seconds and when it starts flashing - or stays on a Sold Color ( red or Blue ) depending on the bluetooth. - - that means it is in Pairing mode.
hope this helps
thanks
Mar 31, 2010 | Nokia 6230i Cellular Phone
Bluetooth Activation Toshiba satellite pro L300
Method 1 :  FN+F8 function should enabled the BT and should stay in this position. Then the BT could be always on.
Method 2 : Start menu -- Run -- Type " fsquirt.exe " without quote. it will automatically find the drivers and activate your bluetooth only if you have the Bluetooth driver installed.
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
My motorola bluetooth h270 appears to be frozen. It won't power off, and won't connect to my phone. Whether switch is in off or on position, blue light stays on.
Put it on charging once again. While it is charging, switch it off. It should go off now. Now, remove from charging and switch it back on. Hope it works for you
Jun 30, 2009 | Motorola Radio Communications
How do I put Jabra BT 135 in Discovery mode?
Turn the device on and continue holding the power on button until the light stays solid. That puts it in discovery mode.
Pair it with your device.
It will probably also ask you for the password to the bluetooth headset (mine did). The default is 0000.
Jun 30, 2009 | Jabra Bluetooth Headset with Adjustable...
Earpiece slipped off the plantronics bluetooth,and i want to know if there is anything to help put it together again.
my plantronics 510 voyager did the same thing. try putting the earpiece back on to the main bluetooth and wrapping a small rubber band BETWEEN THE TWO. the object is to put some opposing pressure on the earpiece to force it to stay on. it'll work at least till you get anoter earpiece
Oct 05, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Bluetooth
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth headset
Put your phone in "Discovery Mode" Most phones can get there by going to Menu/Settings/Tools/Bluetooth. If you don't have Bluetooth option here, your phone probably doesn't have bluetooth capability. Then, on your bluetooth hold down the big button until the blue light stays. If you have a bluetooth that you flip, make sure it is closed first, press down the button until the light appears and then flip the bluetooth open. that should leave the light on. as the light stays on and your phone on discovery mode they should be able to locate each other.
Dec 25, 2006 | Motorola Mobility E815
Radio Communications Logo
97 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
