Question about Sony Audio Players & Recorders
Sony music system push power protect MHC-RV7.plese help sir
Posted by Mostakim Chef on
Larry Ng
  • Sony Master
  • 6,039 Answers
You forgot to say what fails. ,
my guess it needs to be reset? RTM , lost the manual>?
here is the free service manual , RTM?
https://www.manualslib.com/manual/1109674/Sony-Hcd-Rv7.html#
first google hit , BTW.
Posted on Feb 25, 2020
5 Related Answers
Zlobomir
Zlobomir
  • 225 Answers
SOURCE: my sony mini hi fi system.model mhc-nx1.reads ;
Lucky guess: you have an auto-fuse somewhere on the back of the unit.
Posted on Nov 08, 2009
SOURCE: sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Posted on Feb 11, 2009
ABRsvcs
  • 4234 Answers
SOURCE: sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Posted on Aug 19, 2009
Anonymous
SOURCE: my sony mini hi-fi component model HCD-RV7, stereo wont come out
how can i remove push power protect
Posted on Oct 03, 2009
Anonymous
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
this problem is audeio out put is sort .pls ching out put STK .Any Q - My ID [email protected]
any sony music system problem
Posted on Nov 07, 2009
Repair of SONY Music system Model MHC-VX901 for Push Power Protect code+ India
Its stk ic problem. Change stk ic. Purchase from online china website and change stk ic no 412750
Push Power Protector - Sony MHC-VX777 I am getting Standby message and push power protector .My music system was not operated
Hi!
This is what the manual says:
PROTECT"and "PUSH POWER" appear
alternately.
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
"PROTECT" and "PUSH POWER"
appear alternately again after you turn
the system on.
2answers
Protect push power/ sony- MHC RV6
A protect message on a sony usually means there is an amplifier problem.
1helpful
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
2helpful
Sir my sony stereo system showing "protect push power" how i troubleshoot the problem please replay fast
Protect Push Power on a Sony is telling you that you have an output short circuit and to turn off the player to prevent further damage.
Check the speaker cables for connection fault. If all is OK it means you have a blown STK Amplifier Chip. Will cost you about 20$ plus labor.
16helpful
3answers
Protect push power
audio amplifier IC fried need to be replaced
2answers
Protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
2helpful
2answers
Displaying ' protect power ' on the screen.
Replace the audio amplifier IC because are damaged
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
aliasger yq
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
