Question about Panasonic Office Equipment & Supplies
How to setting E02-02 code panasonic photocopier machine
Posted by atta ur rehman on
Lee H
    Habit-Forming:
  • 23 Answers
Hi.
Panasonic Workio DP-1820P error code E02-01 These instructions describe error code E02-01 solution for a Panasonic Workio DP-1520p, DP-1820P copier machine. This should solve your problem; this introduction will help you to troubleshoot some common error messages related to Panasonic Workio DP-1520p, DP-1820P Error Code E2-01, E2-02, E2-03, and E2-04 that you may receive.
Meaning of E02-01 the Error Code:
E02-01 means the Tray 1 cassette lifting motor unit fault. These machines use a lift motor encased in a plastic drive gear casing. Usually something inside the casing breaks, this usually happens in trays that have Ledger or Legal paper installed. The weight of the paper can cause these gear packs to break. Also if the customer loads letter paper in a tray set up for larger paper sizes.
How to fix the error:
Maybe a problem with tray 1 lift motor either you have a bad motor, Pull the paper tray out and see if the paper is lodged behind the tray, Also make sure the white coupling on the rear wall is in one piece. Check that the flag on the back of the tray is still present. Mostly it is broken and sometimes can be repaired, and otherwise, you have to change it, and to open the back cover and reach that (Part no is (DZTY000357 Paper Lift Motor Assembly, lift up drive).
Some of the possible causes:
  • Remove the tray and check for paper behind the tray.
  • Check paper falls back causing the gears to break.
  • Check cassette Lift Motor connector.
  • Replace the Tray 1 lift motor.
  • Check the Mainboard.
Good luck.
Posted on Apr 06, 2020
1 Related Answer
Anonymous
SOURCE: How do I clear machine error code E04-01 on a
How do I clear machine error code E04-01 on a Panasonic DP-3030 photocopier?
Posted on Sep 20, 2010
My photocopier machine panasonic 8020 showing "ADD PAPER" when i already check all try of the machine pl give sutable answer. I awaited for your ans
u have to check the front door interlock switch.this is a common problem with the panasonic copiers .if u have a new interlock switch then replace it,if not then short ckt the same with the help pf a wire and thats all
8helpful
4answers
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
1helpful
2answers
Toshiba estudio 160 Password
Code 08- 263 does not work with the e160
And I cannot find anywhere in the service manual where it specifies how to read it...
1helpful
IP address problem
What problem? Need more info! On the Panasonic brand, you input the IP address through the "function" mode- "general" settings... go to last menu item "key operator" the code should be 3 or 4 zeros. Then go to the IP address item and enetr in the IP adress. Now you MUST TURN THE MACHINE OFF AND BACK ON TO LOCK IN THE IP ADDRESS! Go back into general setting and "print general settings" to see if it's still the same address.
Panasonic FP7117 Photocopier Fault code E3 11
that is for corona assembly first of all confirm that it is charger assembly or lower assembly .first of all put out lower assembly from machine and on copier if coderemoves then clean this assembly and change corona wires .if code still clean charger assembly and change corona wire.cod will bi removed.mian jee
23helpful
5answers
Panasonic FP-D355 Error Code E04-01
the best thing that u do first is to clean the fuser unit, esp. the thermostat located there. then you may go to service mode, (function+orig.size+3), F9, look for ram initialize, then look for LBP FUSER RESET.
it will reset all e4 machine error.
Top Panasonic Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
