Question about Car Audio & Video
I have a nobsound ns-20g amplifier 200w so to get full power what is the amps and volts I can use
Posted by kamran bits on
4 Related Answers
Anonymous
  • 9 Answers
SOURCE: Nuvi 200W GPS power supply will not stay plugged in
hpd367 - If your Garmin has died within a year then call them for an RMA number and they will repair/replace it.
Tel 0808 238 0000
Moscow Nell - I had the same problem and got an adaptor from Halfords for about £5.
Posted on Apr 04, 2008
Joel Friedenberg
  • 1114 Answers
SOURCE: 20-Volt DC Power Supply instead of 12-Volt amp
Here's a few things that come to mind. An auto charging system will operate normally from about 11 Volts to about 14.5 Volts, depending on what is operating (lights, blower,etc), and whether the vehicle is at idle or not. Most car amps will operate from about 10.5 to 16.5 Volts, and outside that range, they will probably shut down.
Another consideration is your 20 volt power supply. You didn't mention if it is a DC power supply, but it needs to be. The other factor is its output, meaning its amperage rating. I'm figuring it will need to put about 5 amps, at the least, for the Sony to put out some watts. I think the line fuses of the Sony are rated @ 25 amps each.
I don't like this type of situation, because I want to say 'try it and see what happens" and I want to say 'don't do it, something may blow".
If you decide to try the 20Volt power supply, maybe if you put smaller rated fuses (say 10 amp) in the Sony amp, they will act as a fail safe. Good luck!
Posted on Jul 27, 2009
Robert Struzinski
  • 182 Answers
SOURCE: 200w audio power amplifier
sounds like it's getting really hot, that round thing your talking about is kind of a step up transformer which causes inductance and will increase the voltage that the other components need to run properly. It's copper wires wrapped around a piece of iron like an electromagnet. So what is you question?
Posted on Aug 07, 2013
Thomas Beaver
  • 2119 Answers
SOURCE: does 12 volts audio amplifier will work on 5 volts?
It's not likely that you will ever be able to do that.
Posted on Oct 26, 2014
How powerful should amp be to run the speakers?
200 watts is the maximum power handling capacity of the speakers. The amplifier should have a maximum power output of less than 200 watts (per channel) at 8 ohms to avoid over driving the speakers and possibly burning them out.
Jan 06, 2016 | Audio Players & Recorders
I have a 250 watt / 4 ohm subwoofer i have a diesel 700w amp / 2 channel / hpf or lpf with bass boost. i dont have speaker wires and want to utilize my to speakers in the back of my 2008 mustang to...
if you are trying to use it with the stock headunit you would need to buy a line output converter to use your amp and sub. after you buy the converter you will then need to splice into one of your rear speaker wires so you can run the rca's to the amp and continue with normal install
Aug 10, 2010 | Diesel Audio NS-700 Car Audio Amplifier
My amp will not power up
try hotting your remote wire to your batter if it don't come on u will need a new amp
Jun 14, 2010 | Diesel Audio NS-1000 Car Audio Amplifier
How many ohms is this amp
your amplifier has the following specs:
Output Power at 12V:
1 x 200W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
1 x 400W @ 2 ohms (0.5% THD, 1kHz)
Output Power at 14.4V:
1 x 300W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
  • 1 x 600W @ 2 ohms (0.5% THD, 1kHz)
May 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
Amp does not turn on
assuming your amp is working fine, locate and use another radio pre out put rca and plug it into the amp and see if that will work. you going to have to eliminate what bad, the radio or the amp. If still no sound than the amp is faulty. you can use home reciever to test it also using pre amp out put plug to the clarion amp. hope that make sense
Nov 04, 2009 | Clarion APX400.4M Car Audio Amplifier
Xplore 2ch 200w amp model 4090 help
Yes there's a way to fix that. The best way to fix that is to bring it to your supplier (if it has warranty and in terms and conditions) or to a certified repairman in your area.
Jun 02, 2008 | Power Acoustik LT-980/2 Car Audio...
NS- 1600 amp
You need to use a multimeter to confirm that you have a good ground and sufficient voltage on the B+ and remote wires. I'll assume that you've checked the on-board fuses (if it has them).
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v and the amp does nothing, the amp probably has a blown power supply.
May 03, 2008 | Diesel Audio NS-1600 Car Audio Amplifier
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
