Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work.
https://homeguides.sfgate.com/reset-buttons-washing-machines-104441.html
SOURCE: Candy GO1482 washing machine blows house fuse
This sounds like an electrical fault within your Candy washing machine.
Have you tried plugging your coffee machine, dishwasher or toaster into the SAME POWER SOCKET?
If so, does this still trip out the mains/house fuse?
If it does, it sounds like there is a fault in your house wiring.
If these "high power" devices/appliances do not cause the same problem, then you may have an Earth Leakage fault on your washing machine or something else inside it has short-circuited and will need servicing right away!
SOURCE: hi, when i try to
Cisco VPN Client for Windows Vista, release 5.0.0.340, does not support the following: •Microsoft Windows NT, 98, and ME. •System upgraded from Windows XP or earlier Windows operating systems to Vista. (Clean OS installation required.) •Combination of Cisco Unified Video Advantage 2.1.2 and McAfee HIPS Patch 4 Build 688. To avoid system failures, uninstall either of these two applications, upgrade McAfee to the latest version, or use VPN Client 4.6.x. •Translated Online Help. Online Help is provided only in English. •64-bit Windows operating systems. For x-64 support, customers should explore with their Cisco sales representative the use of the next-generation Cisco AnyConnect VPN Client.
Did you manage to get this fixed mine is doing the same
Mine is doing the same. Did anyone find a solution?
Help same problem
