Question about Carrier Heating & Cooling
Honeywell VisionPro TH8110R1008 controlling a Carrier FA4ANF018 electric furnace/AC. Heater won't turn on.
Honeywell VisionPro TH8110R1008 controlling a Carrier FA4ANF018 electric furnace/AC. As best I can recollect, the sequence of events went like this: Furnace was working normally. Thermostat was set at 70. Turned temperature on thermostat down to 67 and left the apartment. Didn't notice if furnace was running or not at the time, nor if it was running and shut off when I lowered the temp. Came back an hour later. Furnace was running and temp was up to 72 degrees. Thermostat looked normal. No indication of low batteries. Tried turning the system off on the thermostat. Furnace continued to run. Nothing on the thermostat would affect the furnace. Eventually turned off the circuit breaker (for the apartment electrical, not the breaker on the furnace) to stop furnace. Waited. Turned breaker on. Furnace stayed off. Batteries failed in thermostat and screen went dark with barely readable failing battery message. Put in new batteries. Thermostat fired up but still wouldn't control the furnace. Switched to cooling. AC went on. Couldn't turn AC off. Had to turn breaker off again. Turned breaker on. Thermostat displayed "Wait" message when I tried turning on the furnace. Waited half an hour. Wait message disappeared. Still can't turn furnace on. Slid out lithium backup battery and slid back. Thermostat makes appropriate click sounds as if it is turning the furnace on or off, but furnace doesn't respond. Equipment Status screen shows furnace on or off depending on thermostat settings. Set thermostat to System Off. Checked breaker on side of furnace. Was off. Turned on. Turned temp up on thermostat. Thermostat clicked, but furnace did not go on.
Posted by davecur on
john h
    Top Expert:
  • Carrier Master
  • 24,045 Answers
Possible stat failure
Posted on Apr 05, 2020
5 Related Answers
Anonymous
  • 625 Answers
SOURCE: Heater won't shut off.
you say you hear a click. this indicates the relay is opening and closing, BUT the contacts may have welded itself shut. try replacing the relay - contactor.
Posted on Nov 15, 2007
Ken Bledsoe
  • 306 Answers
SOURCE: Furnace doesn't reach desired temperature
One of two things you can try. Do you own a volt ohm meter? Anytime your unit cycles short like it is doing the control circuit which on this one is 24 volts that engages relays and controls the gas valve to open and close. I am thinking the heat exchanger is getting so hot it is tripping the upper limit which for the most part is around 180 degrees. So next time it turns off take your ohm meter and with the power to the whole unit off. Either turn the breaker off or there is a light switch that is real close to unit turn it off. Undo the two wires to the gas valve and ohm them out. You should have continuity if you get nothing check each limit switch should have a couple. Undo wires to them and check. If you find one that is open more then likely the upper one. They are a safety device that keeps the unit from getting too hot.
There might be another option increase the speed of your fan motor to get the heat out of furnace quicker. Look at the circuit board notice the fan wiring going to it. The Red wire from fan is low speed look to see if it is on HEAT on the board. You should have 4 speeds to pick from you could take the black off of COOL and swap wires and test the unit by doing that. I'm going to put a solution on this so I can come back to it quicker. Even though we a just testing it for now. ken
Posted on Dec 21, 2008
pierre1811
Perry Putnam
  • 144 Answers
SOURCE: Code 32 when wind blows
Hi and welcome to Fixya. I believe that the wind is affecting the draft. What I would recommend is to install a cap on the flue that is similar to a weather vane in that it rotates to block the wind from creating a downdraft in the flue. Some times depending on the direction and strength of the wind it will come up over the roof peak and then down the flue. A regular fixed cap may work too. You should be able to purchase one at your local hardware store. Please let me know if this was helpful. Good luck.
Posted on Jan 25, 2009
Anonymous
  • 56 Answers
SOURCE: thermostat does not follow the setting
If the thermostat is a digital /programmable you may want to recheck program to see if it has changed or been changed. If thermostat is not digital then it is prbably warn out and need replaced.
Posted on Feb 16, 2009
Anonymous
  • 16 Answers
SOURCE: my carrier a/c compressor unit won't start. it
Could be that the compressor is locked up or either start components are bad..... need to get an AMP gauge and see what the AMP draw is when you hear the compressor try to start which is the click, Hmmmm, click your hearing,
Posted on Jul 07, 2009
Dual heat system, honeywell thermostat, auxiliary heat won't turn on
IT SOUNDS TO ME LIKE EITHER YOUR SYSTEMS LOW VOLTAGE WIRING IS INCORRECT, MOST LIKELY @ THE FURNACE. IT COULD ALSO SIMPLY BE THAT WHEN THE TECHNICIAN THAT INSTALLED THE T-STAT AT START-UP DID NOT GO THROUGH THE INSTALLER SET-UP & CHOOSE THE CORRECT SETTINGS FOR A DUEL FUEL SYSTEM. TRY THIS " SET THE THERMOSTAT TO EMERGENCY HEAT, WAIT A MINUTE OR TWO & SEE IF THAT TURNED GAS FURNACE ON. IF SO THEN IT'S A SIMPLE FIX IN THE WIRING OR PROGRAMMING & NOT SOMETHING MAJOR! GOOD LUCK!
Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
How do you reset a honeywell th8110u1003 thermostat honeywell 800 # will not tell me but he said it needed to be reset because off ee code on screen
http://www.pexsupply.com/Honeywell-TH8110U1003-VisionPro-Thermostat-1-Heat-1-Cool-3909000-p YOU MAY FIND THE ANSWER HERE BUT IF NOT YOU CAN FIND IT RESET BUTTON IN THE (FURNACE?) UNIT. THE REASON HONEYWELL WILL NOT GIVE THE INFORMATION IS BECAUSE THIS CONDITION USUALLY MEANS THERE IS A PROBLEM IN THE SYSTEM AND GAS IS NOTHING TO FOOL AROUND WITH. FYI HAVE YOUR IGNITER CHECKED OUT.
Wiring honeywell visionpro iaq thermostat to a carrier mid-efficient furnace
Not knowing the model numbers and if the stat is a programmable heat and cool stat, I will tell you how to wire one that is. On the stat you should have terminals marked RC, RH, Y, G, W. If this is a furnace only with a terminal board, Start at stat. You should have only 2 wires for heat only. Red will go to RH and leave the jumper wire that goes from RH to Rc in place.The other may be white and will go to W. Same at the furnace R to R and White to W.Let me know if this is you're set-up and if not tell me the terminal markings on the stat and carrier furnace and if it is heat only.
Shastalaker7
14helpful
2answers
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
shizznat
Level 1 Expert
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
