Question about Radio Communications
CB radio squeal on transmit, weird SWR, and not receiving static.
Radio is a used Cobra 19 Ultra 2 wired into a 12v lighter plug, coax is 18' amazon grade, antenna is a firestik 4', and its mounted to the bed of my truck. I don't receive any static even with the volume on high and the squelch all the way down. I can receive transmission but it is quiet even when volume is cranked up. Transmitting just broadcasts a squeal to other radios. Best SWR I have gotten is 1.2 on 1 and 2.2 on 40 with the firestik tip adjusted as low as it will go. the closest I have gotten SWR to be is about 3.2 on 1 and 3.4 on 40 with the tip extended. I have checked ground between the cable sheath, mount, and truck bed and the continuity is great (0.001). Beyond upgrading to a new in box radio and/or upgrading all of the wiring I don't know what to do. Any thoughts? EDIT:(I drove around town last night with the cb on and sometimes when hitting a bump I would hear a blast of static. Tapping on the bottom of the radio while on resulted in the same static for a moment.)
Posted by Tim Tarr on
Vernon Taylor
  • 7,125 Answers
I am guessing the CB has a fault and needs taking to a CB Doctor...
Posted on Feb 15, 2020
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: my galaxy 959 cb radio wil not put out any transmit
Based on your post of no transmit, a couple of possibilities:
1. defective microphone or cord or PTT switch (the red TX light does not come on when pressed);
2. TX light comes on but no output, defective finals and/or drivers. These are the transistors screwed to the chassis of the radio very near the antenna terminal;
3. defective regulator IC that provides the TX B+;
5. insufficient amperage from you power supply;
6. too high SWR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 16, 2008
Anonymous
  • 55 Answers
SOURCE: Only get static when trying to receive transmission
Turn the squelch knob eathier up or down to eliminate the static.
Posted on Nov 08, 2008
Goober Pyle
  • 14 Answers
SOURCE: Have Cobra 29 LTD CB
Sounds like the PLL circuit....... no channel synthesizer will kill the transmit and receive...... bad crystal or IC could be at fault or if someone has attempted to add more channels could also be cause.
Posted on Dec 22, 2008
Anonymous
  • 170 Answers
SOURCE: static noise in my cb radio
A lot of times the "static" Is actually a loos connection in the microphone or a dirty micke gain control. Radio shack sells a cheap tuner cleaner if you know how to take the covers of and find the mic gain control, spray it in the little slot in the control( be generous) move the knob back anf forth several times. Also if you have another mike wired for cobra, try it and see if it helps. Those two solutions fix 98 percent of the problems. If it doesn't, please let me know. I am very good with cobra radioes and am sure we can solve this problem.
Good Luck. If this so;ution helps, please rate me.
Tom
Posted on Jan 31, 2009
Anonymous
  • 55 Answers
SOURCE: CB Radio will receive but not transmit
Sound Like The Modulation Amp May Be Dead..
Or a Componet in The Mod. Section....You Can Pick up The Repair [email protected] www.samswebsite.com For about $20.00...Good Luck
Posted on Feb 21, 2009
Static in my cobra ultra 3.
The easiest way to check this is to hook an SWR meter to the antenna to see if the cables are ok. If the SWR is low then it would show no problems in the transmit and therefore the receive would be good.
Mar 03, 2014 | Cobra 25 LTD 40-Channels Base CB Radio
My cobra 18 wx st comes on and goes tru all channels but has no noise at all coming thru it. none of the signal strength lights come on or anything. its brand new.
Sounds like a antenna issue. Make sure coax is in good order.and antenna is connected properly. You might have to get a "swr" meter to put in line between radio and antenna to make sure antenna is "tuned" to were the radio is operating. Radio shack sells a ok low budget swr/power meter.
Nov 09, 2012 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 18 wx st receives-wont transmit
Take the cover off, flip it over solder side up, check all solder joints for cracks, cold solder joints, check the safety diode where it comes in the radio, before I go further, can you pick up the weather channel?...Does the PA work?...need to check the pre-driver and finals,audio chip, hook up the power meter using a coax three foot jumper from the output from radio to the input of the watt meter, then the antenna, first check the SWR, on the scale on the meter to cal/swr mode,adjust it to spec, then while still keyed down turn the dial to SWR,if it is the safe range your ok,then turn the Dial to 10 or 20 watt scale and key the mic. Does it have any wattage? If not suspect the finals, they are located on the back rail, if it does have RF then its the audio chip, its located on the right side rail facing you,closest to you.remove it and replace it with same ....hope this helps....
May 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Won't receive audio or any noise with squelch all the way left
Perhaps a faulty connector on your coax cable. Get it fixed or replaced you coax cable with a new one.
Mar 24, 2009 | Cobra 19 Ultra II CB Radio
Cobra 29 wx st
IF YOU CAN RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Feb 14, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Static and Recieving Problem
make sure people are talking on the channel it may be no one is talking . the static tells you it is receiving something. the cobra 19 and sister radio magnum sold at wallyworld are notorious for having bad solder joints on their boards.
Aug 27, 2008 | Cobra 19 DX IV CB Radio
CB transmission
Hello 64driver,
Make sure the radio is grounded properly and that the SWR is around 1.2:1, 1.3:1 is good but try to get it to 1.2:1. Also take a power output reading while keying the mic. To do this with your power meter put it in-line with the CB and your antenna and key the mic you should get about 4 to 5 watts PEP. If this is the case your unit is putting out the proper power level, if not have the power amplifier checked by a qualified repair shop.
I hope this helps
Shuttle83
May 13, 2008 | Cobra 19 DX IV CB Radio
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Cb transmitting problem
Hello kaelea,
Check your ground wire and by your post I gather that you are user some form of headphone device, I say this because normally the speaker is off when the microphone is keyed. I would also check the controls on the headset if you are using one.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Cobra 19 DX IV CB Radio
Radio Communications Logo
91 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
