Question about Lenovo Computers & Internet
Ac adapter for lenovo thinkpad is lose,connects only at a certain angel,adapter #65w 20v.Is there quick fix or do i need to buy a new adapter
Posted by gopeenath on
Dariusz Zalewski
  • 1,092 Answers
If the plug is the problem then you can replace just the faulty end. Many times actual socket in laptop it the problem and may not to be easy to repair
Posted on Feb 15, 2020
5 Related Answers
Anonymous
  • 557 Answers
SOURCE: the ac power adapter type cannot be
Dell power supplies use 3 wires. One detects the power supply. If you are using a Dell supply then that wire is broken inside the cord or at the connection. If this a universal power supply it only has 2 wires.
Posted on Dec 20, 2009
biian l
  • 184 Answers
SOURCE: have a dell inspiron with
From doing a google search for "AC Adapter Cannot Be Determined" it appears your power adapter is defective and/or the output voltage is not up to full voltage. From the many posts about this that I find doing the google search it's a fairly common problem. If it's still under warranty contact Dell Support. If not, you'd better buy one replacement. There are tons of online stores selling this.
Try this:
http://www.chargerbuy.com/dell-inspiron-1501-ac-adapter-65watt-19-5v-3-34a.html
Posted on Nov 17, 2010
biian l
  • 184 Answers
SOURCE: 20V AC power adapter for Dell 2001FP 20" LCD monitor
Got one at $19.99:
http://www.chargerbuy.com/replacement-dell-2001fp-lcd-monitor-ac-adapter-90watt-20v-4-5a.html
Anuj Datta
  • 165 Answers
SOURCE: Dell Latitude states connect 65W or higher power
Hi Friend, In this case I believe, you can try updating the BIOS of the system and check if that fixes the issue. You can find the BIOS drivers from the following link:
hhttp://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D610&os=WW1&osl=en&catid=&impid=
But please make sure to connect the AC adapter while updating the BIOS
Also please make sure to select the Operating System that is installed on the system
Please let me know if it was of some help?
Thank you.
Posted on Jan 07, 2011
Byron Narciso
  • 679 Answers
SOURCE: when i m connecting ac
Hi Maxinfotech Its a common problem for DELL laptops. Most of the time the cause of this a bad AC Adapter but sometimes a firmware reset for the motherboard is the fix. I recommend you try replacing the AC adapter first than try to reset the firmware which could cause a system malfunction sometimes when not done properly. Thanks for using Fixya
Posted on Mar 01, 2011
Does anyone know the size screw that attached the bottom right had outer cover of the Lenovo G595 laptop computer? The other screws on the bottom seem too small.
Its a very long screw.G480/G485/G580/G585: M2.5×6.0 mm,
flat-head, nylok-coated (11)
G780: M2.5×8.0 mm, flat-head,
nylok-coated (16)
Apr 15, 2014 | Lenovo ThinkPad 65W Ultraportable charger...
Lenovo ThinkPad 65W Ultraportable charger 92P1213 (20V 325A)
Ebay would be one place to find those. However you can buy universal power supply's for laptops at Wal-mat for around $70.00
Apr 09, 2014 | Lenovo ThinkPad 65W Ultraportable charger...
Fan error loose connection
Have it serviced at a local computer repair shop.
Mar 23, 2014 | Lenovo ThinkPad T61 7665 Laptop AC Adapter...
Lenovo x220 charging is in and out
Check your adapter for lose connection. Try to wiggle the connection between your ac adapter and your computer. You can also check your computer's port for any sign of defects.
I hope this helps!
Carlo
Dec 20, 2012 | Lenovo Thinkpad X220 Laptop i7-2640M...
Power cord does not work
Does the power cord plug in to the charger seppertly or is it all in one unit, If it plugs in sepperately end your charger is still good just get a different cord for it,
Oct 25, 2012 | Lenovo Ibm Thinkpad T60 2007-59u Laptop...
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
