Question about Grundig Audio Players & Recorders
Where can I obtain a Grundig TK14 tape recorder power cord
Posted by Thomas Divers on
1 Related Answer
robotek
Graeme Ross
  • 1512 Answers
SOURCE: need new belts for Grundig Tape Recorder TK5 1957
Hi there
You can source an entire belt kit to freshen the old girl up from here
It is a German ebay seller, but may well be your best chance for something like this on Grundig product. Good luck with the overhaul, and thanks for using FixYa.
regards Graeme
Posted on Jul 08, 2009
Grundig tk5
With a bit of luck you may be able to find some adapters to allow a plug into the Line IN port of the computer.
Here is a site that appears to have the Grundig manual if you register ( its free). There may also be some very knowledgeable people there that you provide the info you need.
Oct 29, 2013 | Audio Players & Recorders
When inserting vhs video tape into Sony 6 head video cassette recorder tape will not play and will not be released by recorder
Please reset your unit.Just unplug all the cords from the back of the unit and the power cord as well for 1 hour after that reconnect the cords and turn on.the tape will come out.
Let me know the result
Oct 13, 2008 | Televison & Video
Grundig g2 won't turn on
I have been searching as well, to date, it still won't power on even after replacing the battery, getting a charger and charging the old battery. I also used the reset button and no help. I asked Grundig / Eton for help a couple of times and no response. Very disappointing, it is like Grundig isn't around any more or won't support their own products any more.
Feb 23, 2013 | Grundig NG2B G2 Reporter AM FM Shortwave...
How cfan I obtain user guide for Grundig SCD88 player
These models are out of production and also redundant. It is possible that the battery also had gone weak if the set does not power on, otherwise all what is needed is to get in touch with the nearest Grundig support center.
http://www.grundig.co.uk/Audio.html
Dec 12, 2011 | Grundig Audio Players & Recorders
We have a SAMSUNGA LCD TV. We also have a
You indicated you have a DVD PLAYER, not DVD recorder. You cannot record on to a DVD on a player, you need to buy a DVD recorder/player. Unlike a VCR which stands for Video Cassett Recorder which can record and playback video. DVD recorder technolgy much more complicated.
Nov 28, 2009 | Grundig GU19WDT 19 in. LCD TV
Unlock code for grundig car 200 radio cassette
reset code for grundig car200 casette radio
Sep 02, 2009 | Vehicle Parts & Accessories
Need new belts for Grundig Tape Recorder TK5 1957
Hi there
regards Graeme
Jul 08, 2009 | Audio Players & Recorders
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Dec 30, 2008 | Audio Players & Recorders
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Sheldon Dedek
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
