SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
SOURCE: Self-propelled doesn't work
remove plastic cover to access drive mechanism
check belt and remove debris and try again
Posted on May 26, 2009
SOURCE: SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
Posted on May 30, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
SOURCE: hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Apr 17, 2010
Aug 30, 2017 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Jun 18, 2012 | Toro Lawn Mower With Toro Power Tools
Nov 28, 2017 | Craftsman Push Rear Bag Lawn Mower w High...
Aug 15, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Jun 28, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Jun 14, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Aug 12, 2009 | Toro Lawn Mower With Toro Power Tools
Apr 30, 2009 | Mtd 22" Yard Machine Push Mower
73 people viewed this question
