Question about Sharp Office Equipment & Supplies
My sharp mx 5001n jam in printing colour and photocopy but does not jam in printing and photocopy of black can any body help me out. Thanks
Posted by musa on
Attique-ur-Rehman
    Top Expert:
  • Sharp Master
  • 2,677 Answers
Https://www.google.com/search?sxsrf=ACYBGNT4NAFE4i8H_nUJo3tW8_UkuhgWQA%3A1581700574106&source=hp&ei=3tVGXvD-A8GblwSFiomADA&q=My+sharp+mx+5001n+jam+in+printing+colour+and+photocopy+but+does+not+jam+in+printing+and+photocopy+of+black&oq=My+sharp+mx+5001n+jam+in+printing+colour+and+photocopy+but+does+not+jam+in+printing+and+photocopy+of+black&gs_l=psy-ab.3..35i362i39l10.2711.2711..4155...2.0..0.0.0.......1....2j1..gws-wiz.....10.Do72nUXxrmc&ved=0ahUKEwjw5e7mxdHnAhXBzYUKHQVFAsAQ4dUDCAU&uact=5#kpvalbx=__91GXtj_OIusa-e2q-gM31
Posted on Feb 14, 2020
5 Related Answers
Anonymous
  • 93 Answers
SOURCE: Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Posted on Mar 14, 2009
Anonymous
SOURCE: Sharp MX-4501N Mac drivers 1.1
You are using Bonjour to print to the MX-4501N which uses a generic post script driver. To fix this, you must install the printer using the proper driver from Sharp. For a first time install, download the drivers, install the drivers, restart, and install the printer as an IP printer, specify the IP address, it should be using the LDP (Line Direct Printing) protocol, and specify any additional optonal accessories you have on your MX-4501N. Hope this helps :)
Posted on Apr 24, 2009
fredtmccoyjr
Fred McCoy
  • 380 Answers
SOURCE: My new Sharp MX-5001N printer
Create them in Word perfect, but see if ms word will open them. You can likely get word to print them. You can also try the collate feature of the printer in the printer settings.
Posted on Nov 11, 2009
Anonymous
  • 91 Answers
SOURCE: can not take colour print out, black colour
problem with drum unit. sometimes unit comes with cartridge and sometimes as a maintenance kit.
Posted on Jan 15, 2010
didi2005
  • 727 Answers
SOURCE: Toshiba colour photocopier jamming when copying or
"CEEO" indicates Transfer belt position detection abnormality.
U need to service the transfer belt unit, especially the reflection tape and sensors.
Posted on Apr 02, 2011
Selected servers not found
This is a common error when using Sharpdesk and the Network Scanner tool. Take a look at my cheat sheet on how to fix this problem.
Sharp Scanner CE 02 Cannot Connect to Server Consult your Network...
Aug 26, 2013 | Sharp MX-5001N Copier - 50 PPM Full-Color...
I have a MX - 3500N colour sharp copier. Magenta colour is completely missing whenever i photocopy.
How many ink cartridges does it have [ 1 black & 1 color ]
OR 1 black & 3 color ?
Aug 10, 2013 | Office Equipment & Supplies
My Mx-4501N Sharp copier whenever i send black it will print well but when i send colour it will jam
You need to have a service call, call a local sharp dealer. There is a dealer locator at www.sharpusa.com
Jun 04, 2013 | Office Equipment & Supplies
WE NEED TO CHANGE THE DEVELOPER IN OUR SHARP MX 5001N COLOR COPIER
The developer change is quite easy, have you ever done anything like this before?
Is it just black or colours as well?
Jul 12, 2011 | Sharp Office Equipment & Supplies
My new Sharp MX-5001N printer has duplex capabilities and I have been able to accomplish this through MS Word, but the document I'm merging now is Corel WordPerfect 12 and with everything set that should...
Oct 20, 2009 | Computers & Internet
Sharp MX-4501N Mac drivers 1.1 will not hold black and white colour setting in printing profile (save as)
Oct 09, 2008 | Sharp Office Equipment & Supplies
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
