Question about Poulan Garden
Poulan woodshark p3314wsa new plug, good spark. New carburetor and lines. Still won't start
Posted by Floyd Elliott on
Carl Rock
  • Poulan Master
  • 3,136 Answers
Suggest you try starter fluid as a diagnostic. Remove air filter and spray 1 second short burst directly into carburetor, promptly pull starter cord.
If it fires, then no fuel from carburetor. Comment here for further assistance.
Posted on Feb 16, 2020
1 Related Answer
Anonymous
  • 2220 Answers
SOURCE: disassembly of poulan woodshark model p3314wsa to
This is an IPL for a Poulan P3314 (may not be your saw), It seems there are 2 different size hoses, I suggest you disturb only what is necessary, take a digital photo, then a small sample of both sizes to a local saw outlet. 12" of both sizes should be ample, ask for his guidance before you order.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P3314-530165402-952802026.pdf
Many also find this helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If not your saw try here (there are 3 "P3314WSA"s available):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The IPL can be used as a disassembly guide too, although you should not need disassembly beyond removing a cover or 2. Good luck with your project If I can be of more help you can reply below. HTH
Lou
Posted on Jan 28, 2010
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
My poulan woodshark model # p3314wsa bogs when I start to cut how do I fix it runs fine when not cutting
Remove the muffler, and check the spark arrestor to see if its clogged with Carbon. Clean it by either wire brushing the carbon, or heat the spark arrestor with a propane bottle torch, and the carbon will burn off.
Nov 17, 2013 | Garden
I have a poulan woodshark i traded for a old tv it has great compression and great spark but it wont start i think they might have messed with the carb what should i do thanks
Turn the carb adjustment screws all the way in and then turn them 1 full turn out and try that. If it starts it will probably require some fine tuning or some tweaking to get it to start. I also suggest you clean and kit the carb just to you know it has a good diaphragm and no clogs
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 17, 2013 | Poulan Garden
My Poulan Woodshark 14" type 2 (-2 on serial
Fuelleaking from the cap will not stop it running, 40-1 with good quaility two stroke oil shoule be fine, if there is a good spark and fuel at the plug, you need to check that the piston has not picked up, the hottest part of the engine is the exhaust side, so remove the muffler, and take a look at the piston skirt throught the open exhaust port, any signs of scuffing and it will need to come apart to check the damage.
Oct 11, 2011 | Garden
Put new spark plug in new gas clean filter followed starting directions want start
The fuel system may need tending to. It may need new fuel lines, a cleaned fuel filter and the carburetor cleaned and adjusted. If this is an older unit, (even a couple years old) it may require some new internal carburetor parts as well. I don't like being the bearer of bad news, but this isn't always an easy fix. Your specific problem has to be diagnosed and by process of elimination, the problem resolved.
Oct 05, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Disassembly of poulan woodshark model p3314wsa to
Poulan.com
Lou
Jan 28, 2010 | Poulan Garden
Garden Logo
Top Poulan Garden Experts
Jay Finke
Jay Finke
dannydoesita
bryan st
Are you a Poulan Garden Expert? Answer questions, earn points and help others
