Question about Toshiba Televison & Video
The whole picture looks like it shifts every 2 seconds. Is there a board that needs replaced? Toshiba 50 in.
Posted by Randy Farwell on
1 Related Answer
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Picture for about 30 seconds but has sound. TW-5592W82003990
I would first take a look at the screen with set on in a very dark room with a flashlight---do you see a very faint image or picture? That would indicate a back light issue-----Good luck getting a board, I hear the company is again out of business.
Posted on Nov 06, 2012
I have a 50 inch Toshiba 50L4300U that has no picture but has sound. What board do I replace?
Do this test first. With the TV on normally, shine a flashlight on the screen. look for a dim moving picture.
1) If you see one, the backlight led driver isn't working.
2) If you DON'T see a picture replace the T-Con board.
You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 21, 2016 | Toshiba 50L4300U 50" 1080p LED-LCD TV -...
The picture bottom centre has gone out of shape. For example some one standing to the side in the picture looks pregnant. The picture is out of shape please help ;(
Tv have a problems,known as a convergence problems it is dead.Tv have R,G,B colors lines mis alignments,have colors shahows pictures or 3D pictures look alike?Yes,the tv convergence board it is dead.Convergence board must be replaced 2 STK convergence ICS and some or all of it resisters too.To fix the convergence board to fixed the tv convergence pictures problems.The shop will cost u like $300-350 for parts and labors.
Jun 05, 2011 | Toshiba 50A61 50" Rear Projection...
I had a picture for a few seconds, the dvd sound still came through, no picture, , now i get no picture, or sound
The high voltage deflection board needs replace, and to have it repair, you are looking at around 450.
May 04, 2011 | Toshiba 50H82 50" Rear Projection...
Focus error 50h81 toshiba red line problem
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or have 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix it.To solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Toshiba 50H81 50" Rear Projection...
Toshiba 50HX81 TV looks kind of old school 3D with red and green hue. Bad bulb? How involved is this to fix and where do I find parts?
No,not the bulb problems.Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The Toshiba tv have a "HYPER BOARD"known as a convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,must be replaced to solved the tv convergence pictures problems.U have tools like a soldering iron,desoldering pump or desoldering braids,solders?Can u do basic soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop,will cost u $300-350 for parts and labors.
Oct 21, 2010 | Toshiba 50HX81 50" Rear Projection...
So the colours match up on the left hand side of the picture, and progressively fan out towards the right. The convergence had to be lined up manually for to come to this view. As well the picture has...
The "Hyper board" known as the tv convergenece board,it dead.Any colors lines R,G,B mis alingnment anywhere in the picture,have colors shadows pictures or 3D pictures.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts,must be changed on the tv convergence board,to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 13, 2010 | Toshiba 50HDX82 50" Rear Projection...
50" Plasma turns off and back on without picture; audio stays on
Yes, you are correct. there are a few component issues on the power circuit board that will need to be replaced. the mani component will be the capacitors and transistors.if not repaired soon, this unit will completely stop working.
Mar 11, 2009 | Mitsubishi PD-5030 50 in. HDTV Plasma...
Our display board was replaced now the y sustainer board needs replaced
Three suggestions:
Contact http://www.ptscorp.com/television.html. They have a selection of replacement boards or will repair it Fees are usually $50 to $125 and I have had great success with them.
Another would be to try www.shopjimmy.com and lastly do a Google search, if you know the exact part number, to find other sources for the board.
Sep 04, 2008 | Toshiba 50HP66 50 in. Plasma Television
Open Questions:
Televison & Video Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
