Question about Staples Office Equipment & Supplies
Cartridge is full, green light on, but won't staple. Cartridge taken out and do not see where there are any broken, bent staples anywhere.
Anonymous
SOURCE:
Anonymous
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
joboo1
Jim London
  • 257 Answers
SOURCE: Haubold 1400 series Staple Gun has blown an ''o'' ring.
Hi, I repair lots of tools and ended up buying a complete like 2000 part o ring kit I keep in my shop, it has proven invaluable, If you can't find the o ring at a hardware store, give ample supply a call and see if they can help you, their number is 1-800-339-5667.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 27, 2009
goalie39
Ed
  • 479 Answers
SOURCE: stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Posted on Apr 30, 2009
Anonymous
SOURCE: Staples penetrate, but do not bend
If you unscrew 4 bottom screws to lift the top cover, you may find out that there are 2 orange rubbers above its hammer that broke and needs to be replaced.
Posted on Jun 25, 2009
Anonymous
SOURCE: Swingline 520e does not staple
The trick to clearing this is to rn the stapler WITHOUT the cartridge in. We removed several visible jams, but once we ran it with the cartridge out, a huge piece of staple came out, and then we were able to put the cartridge back in and use it. Woot!
Posted on Apr 23, 2010
How to replace staples
If you have the internal finisher that resides in the center of the machine: open the slotted front cover, it folds down towards the ground, then push the green lever sideways to slide the finisher out to the left. Look inside the open area for a green item, push down to eject the cartridge. Pinch the clear cartridge on the arrow to eject the clear part, replace with a full cartridge and reassemble in reverse order. How to replace staples on Sharp printer internal finisher
Jul 21, 2014 | Sharp Mx-M363n Copier, Printer & Scanner...
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
Nov 03, 2011 | Tools & Hardware - Others
After shooting a staple the driver does not return up into the stapler.
obvious answers are 1. a burr on the striker, 2. a bent striker. 3. a trapped staple 4. a broken return spring. other than that I cant help you without seeing it.
Feb 02, 2011 | Senco 300120n Sksl Medium Wire Staple Gun...
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
Jun 25, 2010 | Swingline 87850 Optima PowerEase ? Full...
How do I change the staples in the bizhub 200?
If you have the finisher pictured above: If the machine is asking for staples, press "Finishing" on the panel then "Add Staples" this will move the staple unit to the front of the finisher. If the machine is not asking for staples but is not stapling paper then you may have a staple jam. To get the staple unit out: Open front door of finisher, Locate green turn wheel (this is horizontal in bottom left of finisher front door and is connected to white gears) turn this green turn wheel and the staple unit will be moved to the front of the finisher. Remove blue staple cartridge and remove the staple jam. After you reinstall the cartridge into the staple unit just close the finisher door and the unit will move back to home position on its own.
May 13, 2010 | Minolta bizhub 200 All-In-One Printer
I need to change staples
Jan 06, 2010 | Minolta bizhub 200 All-In-One Printer
Sep 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Lanier 5235 Stapler Problem
Try a new staple cart. as the staples are not advancing. -Carl
Feb 09, 2009 | Lanier 5235 Printer
Load Staples in a Canon ImageRunner 2200
First step, have staple cartridge on hand, type J1 for the iR2200.
Open the front cover of the finisher, which is the door directly below the control panel, which opens from left to right.
There's a handle to grab on the front right corner where the paper comes out, pull it out all the way.
This will expose that module's back right corner where the green staple holder handle is.
With thumb and forefinger, reach in, take hold and lift up and pull out the staple case by its green tab.
You'll see "push" on the sides of the staple case, squeeze thumb and forefinger, one on each "push" sign, and the top will spring up, which is the clear plastic case through which you can see a large spring. Pull out the staple cartridge from the back, under the green tab.
Put the new cartridge in with the orange seal tape hanging out the back.
Press down on the spring-loaded case until it clicks into place again.
Remove the orange seal tab by pulling straight back, then down, not at an angle, as you don't want it to break, just to come off.
Holding it by the green tab, lower the staple case back into the finisher until it settles snugly into place.
Hope that helps!
Feb 09, 2009 | Canon imageRUNNER 2870 Copier
The stapler is not working
Take a can of can air after you have removed the staples cartridge and blow out the socket that the staples fir into. Sometimes a jammed staple can stick in there and cause problems. Also if you can remove the bottom blade of staples out of the staple cartridge. Just raise that piece with the green on it and carefully remove just one blade.
If that does not work you most likely need a new stapler assembly and they could cost 2-$300. retail. If its under contract with a dealer this should be replaced for free.
Good Luck!
Jan 08, 2009 | Canon IMAGERUNNER 2230 Copier
18 people viewed this question
Top Staples Office Equipment & Supplies Experts
Mitch Vass
Mitch Vass
Jim Keysor
Marvin
Marvin
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
