SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
SOURCE: viper auto alarm stuck in valet mode
u can open the drivers door if u have a 2 key remote just press lock aux lock again pretty fast and u should be great.
SOURCE: 2004 Ford Explorer not starting
Is the engine turning over? When you turn the key to the on position, does it behave normally? IE, do the battery and airbag and other lights come on when you turn the key to on position?
SOURCE: 2002 Dodge Stratus fuse box diagram.
If this is factory installed alarm the fuse most likely is in the fuse box under teh hood and market on the lid. It should be located next to the battery. If this is an after market alarm that was installed you will need to locate the alarm speaker and trace the lines back toward the battery and locate the fuse on the wires.
SOURCE: Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
