Question about HP Office Equipment & Supplies
Hp officejet 6860 wont use remanufactured ink. It gives an error.
Posted by Karen on
5 Related Answers
Anonymous
SOURCE: HP OFFICEJET 4215 cartridge error
Try this while standing on one leg.
1. OPen ink caridge lid.
2. Remove the affected cartridge.
3. Close lid
4. Try to print. This will fail, but that is ok.
5. Open the ink cartridge door again.
6. Remove the other cartridge.
7. Unplug the unit.
NOTE FOR THE NEXT STEP
This can be risky and I asume no responsibility for pressng too ******* the contact points, havng too much alcohol, using the wrong kind of alcohol, or not using alcohol or other such problems that can occur.
8. Using ONLY alcholo lightly brushthe contact points
9. Lightly clean the cartridge cotact points.
10. Plug in the unit
11. Install the cartridges.
12. Go through the alignment process.
13. Switch to the other leg, those with one leg only are exempt.
14. You just might be ready to print again.
I know this sounds crazy but this just worked for me.
Callan
Posted on Dec 23, 2008
Anonymous
  • 2120 Answers
SOURCE: ink level monitoring on officejet 6310
Yes. Never refill or buy refilled ink carts.
Posted on Jan 31, 2009
Anonymous
SOURCE: error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
Posted on Mar 05, 2009
Anonymous
  • 169 Answers
SOURCE: I can not install my HP Printers Officejet-- gives fatal error
This issue requires some serious trouble shooting and solutions cannot be posted as they are too long.
If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
Ben Johnson
  • 685 Answers
SOURCE: my hp officejet J4680 printer is giving an error
Try this...
Posted on Oct 26, 2009
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges.
Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
Aug 31, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
Hp officejet 4630 will not work with remanufactured ink cartridge
most wont.. they require the original expensive replacement cartriges..
Feb 02, 2014 | HP Office Equipment & Supplies
How do i find ink levels in Windows 8 for HP Office Jet J4580
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Apr 12, 2013 | HP OfficeJet J4580 All-In-One InkJet...
ATASCO HP OFFICEJET J4585
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
Additionally, severe cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
Feb 22, 2013 | HP OfficeJet J4580 All-In-One Laser...
How to reset hp 901 ink
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered by Costco and Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels CANNOT be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty - it uses fusible links so the electronics are literally blown - thus non-reversible).....so you just need to live with the low ink messages and ignore ink low, non-genuine, counterfeit, fraud messages and similar while you are using these types of refilled or aftermarket ink supplies.
Refer to Inkjet411.com sitelet for all printer models which use refilled ink cartridges (most major brands and models) - see videos below on HP 901 and 901XL low ink warning messages, along with all the other more severe error messages:
http://inkjet411.retailinkjet.com/
Jul 24, 2012 | HP OfficeJet J4580 All-In-One Laser...
HOW TO RESET 920 INK CARTRIDGE ON HP OFFICEJET 6500 AFTER HAVING IT REFILL
FYI, you cannot reset the ink it self. If your using an HP refilled ink cartridge the warranty of your printer will be void. you need to contact HP right away to purchase new ink cartridges.
If the cartridge has been refilled or remanufactured, 'Low on Ink' or 'Ink Alert' messages may be inaccurate or display incorrectly.
Jan 31, 2011 | HP Officejet 6500 Wireless All-in-One...
Cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Sep 21, 2009 | HP Office Equipment & Supplies
HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
May 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
Ink level monitoring on officejet 6310
Jan 31, 2009 | HP Officejet 6310 All-In-One InkJet...
efs_perpends
efs_perpends
k24674
