Question about The Office Equipment & Supplies
My rokenbok control tower with the eight power cartridges doesn't power on
My tower doesn't turn off
You may have to replace the power button switch could be faulty. John
Apr 23, 2012 | Gateway Computers & Internet
Blinking lights
Power off printer, remove power plug from printer, remove usb cable from printer, pull out paper and check for jams, check toner cartridge, clean area underneath the toner cartridge head, uninstall printer from windows control panel, reboot computer, plug-in printer with a different working usb cable, plug in power to printer, power on printer, reinstall printer driver. All in those steps exactly. If that doesn't work I would say you have a bad printer on your hands.
Nov 16, 2011 | Dell 1110 Laser Printer
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspireā„¢ T180 PC Desktop
Do I need a special table to set up rokenbok?
No, I have a set and it can go on anything, just don't let the trucks fall off.
Jun 02, 2011 | Toys
Need the instructions for conveyor belt
Here are the Rokenbok plans/manuals: http://www.rokenbok.com/hard-hat-area/building-plans-plan-books
Feb 16, 2011 | Rokenbok Conveyor Company Start Set
I cant find the manual on the Rokenbok website. it is not listed with all of the Old systems.
We just uploaded this building plan at http://www.rokenbok.com/hard-hat-area/building-plans-plan-books. Make sure to refresh the page if you don't see it.
Rokenbok Toy Compan
Jan 29, 2011 | Rokenbok Rc Fire and Rescue _
The Rokenbok monorail will not move forward or backward. And the basket on the monorail moves on its own without stopping or without touching any buttons.
We had the same issue here. The motor would run but the drive rollers would not move. I took the entire engine assembly apart and determined that the drive gear (pinion) on the motor shaft had slid out and disengaged from the other gear(s). I pushed it down to re-engage it and it works. A spot of glue where the gear meets the shaft seems to hold it in place. Good luck - lots of screws.
Jan 22, 2011 | Rokenbok Monorail Metropolis Start Set by
I have an old rokenbok sweeper truck that just will no longer work. I've changed the batteries and checked the connection on the radio control, but still nothing.
check and make sure there is no corrosion on both the truck and the remote.If thats not the problem,then you might have something that needs to be replaced inside the truck.
try it in a different area to make sure nothing is interrupting the signal.
Aug 28, 2009 | Rokenbok R/C Power Sweeper
"I have a Rokenbok R/C Power Sweeper and the wheels on one side don t work"
I don't know how this ended up saying it was a Rolls Royce..........This is regarding a toy...I have a Rokenbok R/C Power Sweeper and the wheels on one side don't work
May 12, 2009 | 2006 Rolls Royce Rolls Royce Corniche
16 people viewed this question
Top The Office Equipment & Supplies Experts
Thomas F. Schneider
Keith Love
James Cagle
James Cagle
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
