Question about Panasonic Office Equipment & Supplies
How do i replace the feed rollers on a panasonic kx-fl511 fax?
    Top Expert:
  • Panasonic Master
  • 30,888 Answers
You don't, you just clean them with hot soapy water to make them sticky again. If they are physically damaged contact a local panasonic office products dealer. Only they have access to parts like that.
https://www.google.com/search?q=replace+the+feed+rollers+on+a+panasonic+kx-fl511+fax
Posted on Feb 14, 2020
5 Suggested Answers
Anonymous
  • 33 Answers
SOURCE: KX-FL511 Panasonic Fax machine will not receive document
Try going through menu and turn ECM to no or invalid also try adsl filter on incoming line
Posted on Mar 05, 2008
Anonymous
SOURCE: Keep Adding Toner to Panasonic KX-FL511
Does this also fix the "change drum" message even after the drum is replaced?
Posted on Apr 02, 2008
Anonymous
  • 82 Answers
SOURCE: Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Posted on Apr 06, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: "Check Document" message
look for a switch trapped down in the document feeder
Posted on Jan 29, 2009
Dwayne Bowers
  • 86 Answers
SOURCE: need user manual
You can download a manual here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/model.KX-FL511
Posted on Feb 06, 2009
Document won't feed
Paper Pick up Rollers get dirty or worn out with the passage of time. Hence, require cleaning or replacement if worn out. In case you find them dirty use a soft, dry, lint free cloth to clean the rollers. Dont use chemicals as they may damage the rubber and plastic. However, if needed, you can use damp cloth or some cleaning liquid such as mild detergent of glass cleaner to damp the cloth. As you have posted your question under Panasonic KX-FL511 is would highlight the steps for it. Im Using a similar model KX-FL612
After lifting the top cover, you have to pull down the under part of it down to locate the rollers
Lift the top Cover, Locate the roller and clean them..
Hope it helps! Good Luck!
CreativeTECH
Dec 01, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
How do you program the panasonic kx-fl511 to print fax confirmations sent.
How can i remove call service6 problem on my
Problem with the Panasonic KX-FL511 Plain Paper Laser Fax
Jul 07, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
My fax machine is showing failed pickup error, what shall i do
CreativeTECH
May 03, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
Trying to fax it reads sending 1 it will not pulled paper through
Try changing your separation pad . If your feed roller rotate clean them with alcohol.
good luck
Oct 07, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
How do you adjust paper feed on a panasonic kx-fl511fax/copier
One of two things is happening ok maybe three. If the machine thinks the size of the paper is not what u are using this could happen. Try:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL511%20Laser%20Fax%20Machine.pdf
For any adjustment you could make.
The second is the paper is getting picked up a little late. The machine knows it did not print the entire page and finishes the job. Try cleaning the pick op roller.
The third is the page being sent to you is to long. This would likely be from one location only. There machine could be slipping when scanning and "extending" the page it is trying to send.
Hope this helps
Mar 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Need user manual
Feb 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Kx-fl511 wont pick up paper
try cleaning the paper pick up rollers with rubbing alcohol, use a cloth rag and the alcohol, try to rotate the rollers so that you can clean all the way around
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax rollers
what kind of roller do you want to install...in feeding unit or in fuser unit?
Dec 17, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
19 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
