Question about Dryers
I have a old pro pull winch mod# 1-9700. I have lost the 2 prong hand held controller. I cant find a 2 prong /wire controller. They are 3 prong. What can i do to make this winch work again.
Posted by Jay Grace on
john h
    Top Expert:
  • Dryers Master
  • 24,045 Answers
Notify pro pull or online search--sites like ebay -amazon both have them for sale including units used for sale $34 their are other companies that sell the remotes as well
Posted on Apr 09, 2020
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: Rainbow Vacuum Model D3B
If it won't work without a ground wire, but still works with one, then you must have a ground/earth connection to make it work - it sounds like there is a safety device that needs an earth to release, you could almost certainly bypass this relatively easily, but it will be there for a good reason and that would be dangerous. Bearing this in mind, regardless of which 2/3 prong adaptors you use, without an earth connection it will not function without risk probably of electric shock from the case or damage to the vacuum, else the safety device would not be there. Get an electrician to your home, and make him install grounded sockets where necessary (should be all, but at least get a couple). Ungrounded/unearthed domestic power sockets at all domestic AC voltages are lethal eventually, to man or machines. A lot of devices don't need an earth, but especially something with a big motor or a metal case usually does. At least ask a local electrician what he thinks. If you want to do it yourself, an Earth circuit in your home is not too hard to achieve if you have basic wiring skills (and access to the ground floor), but most insurance would dislike the idea - if you want to - post again and I may talk you through it. Hope this helps :) Please be careful :(
Posted on Mar 24, 2007
Anonymous
  • 10865 Answers
SOURCE: need wiring instructions to install a 4 prong wire from a 3 prong wire
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
go to this link and you will have your solution
Posted on Apr 20, 2009
Anonymous
  • 323 Answers
SOURCE: frigidaire self cleaning stove mod FEF369cgsb
Vivian
the original wiring probably had a red, white, black, and green wire. It is 240 volts. The red is hot, carrying one leg of 120 volts. The black is also hot, carrying 120 volts. The white is neutral, and the green is the ground.
I am against altering this, but you can wire the red and black each to a hot leg, and wire the white and green to the bottom ground. This then introduces a ground wire to your neutral bar in the circuit panel, which is not the best way to do it, but will work.
Best to get an electrician to wire a 4 wire cable to a four prong outlet, and then use a four wire pigtail with a 4 pronged plug.
Lots of people modify it, they ground the green wire to the stove, where the wire originates,and to the box with the outlet in it where it hooks onto the plug if it is metal. Then you have a part ground. And that is assuming you have a cable with wires sticking out to wire to a plug.
Boils down to your decision. If the above isn't the case, get a four pronged outlet and wire the red and black to the top two prongs, the white to the neutral, and the green to the metal box it sits in.
Sirwriter
Posted on May 16, 2009
TheMobilian
Dan Webster
  • 8221 Answers
SOURCE: old capassitor has 3 prongs new capassitor has 2 prongs
The old motor relied on a leg off of the ol cap marked FAN. No need to bother with it anymore because the new motor probably has a different cap rating therefore it needs its own wittle capacitor. Cute ain't it? That new motor will probably have a common wire to connect to that Old cap at the C mark on it though. It will have 2 brown wires to connect to that new cap for it. (insulate that cute little cap to prevent any shocktastrophies) The black wire will of couse go to wher the old one did on the contactor. Read a little ditty I affectionatly wrote for further info entitled 'old motor had 3 wires new motor has 4 WTF"
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 06, 2009
Anonymous
  • 1776 Answers
SOURCE: I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Posted on Sep 15, 2009
8500lb. motomaster winch- pulling up dock when winch all of a sudden goes into reverse?? Could this be the hand-held or the winch itself? Runs off a marine battery with a battery tender
it could be either one will need to test the switch with a meter if it got hot use of power will heat up unit the switch can malfunction or the power circuit in the winch did the same --moisture also plays havoc controls check also that no water seepage from cable interfered with power
1helpful
2answers
My winch don't move it all?
if you can use the winch manually by pressing buttons on the winch then the problem will be in either the remote unit(Battery in back to front) or the receiver in the winch
What is the wiring diagram for winch remote
Ramsey website shows Badger wiring diagram for solenoid hookup etc but not plug. Shouldn't take a good DIY mech or auto electrician too long to work out which wire goes where especially if they loosen the socket it plugs into which should reveal which wires go to where on the solenoid block. Basically that's all they do, there's a supply side, a ground wire and all the hand control does is switch the supply to the solenoid for forward and reverse. From memory there's only 4 wires? Supply to hand control,1 wire to one sol, 1 wire to other sol, 1 ground wire. Supply could be red, ground is usually black, fwd / rev will be 2 other colours. Look at the socket to see match up?
I need a winch wiring diagram
The third wire should be the extra ground wire and is usually grounded to the metal body of the device.
1helpful
Polaris ranger problems
put jumper leads from a battery across the main terminals of the winch It should work one way Then reverse the polarity and it should work the other way. If so the winch is good . undo the hand held and check the switch by using a multi meter for continuity on the leads as you switch from in to out.(forward reverse)
Wire guage for winch hookup
B I G!!!!! Depends on the amperage but I'm going to recommend at least 2 aught. That is not #2 either. 2 aught, not as big as 4 aught or 3 aught but pretty big copper wire. 4 aught is 1/2 inch thick (almost), 2 aught is 0.365 thick so almost 3/8 inch. The bigger the better for a big winch.
Is their any way to ground a three prong house plug-in from a two wire
replace the outlets to 3 prong IF there is 3 wires in wall if not you cant do anything except replace wire
Jan 16, 2012 • Dryers
1helpful
2answers
N.Z. Yamaha FZ6S Headlights
There is a genuine reason why this is the standard setup for this bike. At night, the dual-headlight of the bike can appear to other motorists that you are in a car at a much greater distance than is actual. As you can imagine, this might result in someone pulling out in front of you, completely unaware that you are bearing down on them at a short distance. So, for safety reasons, only a single beam is lit when using dipped/low beam.
However, if you accept the risk above, you can do what is known as the 'dual headlight mod'. There are 2 accepted methods for this.
The first method simply requires bridging the 2-pin connector (H7 bulb) to the spare on the 3-pin connector (H4 bulb). Instructions have been posted by ‘Gand’ at the following link:
http://solsar.com/fz6/headlight.htm
The second method is more complex, and requires a decent knowledge of auto-electrics, as you have to remove various components of the bike just to get to the wiring loom. Sorry, I've lost the link for this, but you might be able to find the instructions by searching for 'FZ6 dual headlight mod'.
Note: it differs from country to country, but in the UK (for example), the dual headlight mod will result in an immediate MOT failure. Therefore, you will need to remember to disconnect the mod prior to MOT inspection.
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
