Question about Daewoo Refrigerators
I have a cooling fan with a broken blade on my Daewoo WM1010CC that I need a replacement for. Would you be able to assist me with either the motor or fan blade. I have photographs of the replacement parts I need I would really appreciate your help. Thank You, Mike
Posted by thelovittagn on
5 Related Answers
Anonymous
  • 124 Answers
SOURCE: Whole house attic fan
a simple capacitor tester will tell if the capacitor is bad. turn off power, label wires and where they go and test cap after discharging it . to discharge simply connect the terminals together once its been removed( you can use an insulated screwdriver to connect them and discharge any stored voltage) and then touch meter leads to each set of terminals and read the microfared output. the setting on the meter is usually labeled uf. or you can take it to the electric motor shop and let them test it. it has a rating value labeled on the side. usually it has to be within 10 percent of the rated value or its bad . if the cap checks good then the start winding in the motor is probably bad or weak, then a new motor is called for, it is usually not worth the time wait and trouble of getting it rewound etc. take the old motor out and label and measure exactly how and where it was mounted. label and make diagrams. saves a lot of time reassembling exact as it came out. turn off the power , check it with a meter to be sure , short it with a screwdriver to be sure the meter works ,and then treat it as if it was still hot as much as possible when you work on it.
Posted on Oct 09, 2008
Anonymous
  • 95 Answers
SOURCE: Replacement Motor for the NuTone LS80SE Ceiling Fan
https://www.centralvacuumstores.com/nutone/fan-motor-ls-series.php
Posted on Mar 02, 2009
Anonymous
SOURCE: Fan Parts Hunter Fan Type C Model 25436 No. 017626
Cool Breezes Cool Breezes carries parts for old fans that Hunter no longer carries parts for COOL BREEZES 1335 W Campbell RdRichardson, TX 75080
(972) 690-4580push2talk //-->
Posted on Apr 06, 2009
SOURCE: Blade replacement
the lever on the clippers locates into the cutter of the clipper blade its only a matter of lining the lever up with the slot in the top blade which you can slide from side to side by hand. Please keep in mind wear on this plastic Drive Lever may lead to cutting problems.
Posted on Apr 25, 2009
Anonymous
  • 41 Answers
SOURCE: Cooling fan motor is making loud humming noise
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
Posted on May 18, 2009
WM1010CC Microwave Oven won't stop cooling
I regularly repair these.
Feel free to contact me via my site with your full model number and FCC ID number as shown on the tag in or on the oven for free help.
Nov 27, 2016 | Daewoo WM1010CC Microwave Oven
How to replace condenser fan blower wheel and where can i get one ?
Hello, in order to replace the condenser fan you will need to remove the motor aseembly and use a hub puller to remove the fan blade. When removing the fan blade spraynsome wd- 40 on the motor shaft and then attach the hub puller to remove the fan blade. You csn buy the fan blade at any heating and cooling store.
May 07, 2012 | Continental Heating & Cooling
My air condotioner is blowing out warmair.It blows out cold air forabout 5 minutes then warm again it's a 5050 series
It sounds like the unit is cycling on internal overload. The overload is switch the protects the motor from getting too warm. This would explain your cooling "cycling".
Check the condenser (the outside coil with vertical fins, the back of the unit). Is it clear of any debris? If not clean it using water or compressed air, using care not to bend or damage the fins or electrical wires/components.
Check the condenser fan motor. You can usually see the condenser fan motor through vents in the sheet metal. Check to see the the condenser fan motor runs when cooling is turned on, secondly check to make sure the fan blade is not broken, usually the blades are plastic. If the motor or fan blade is bad, you need a replacement.
Jul 12, 2011 | Goldstar WG5000 Air Conditioner
I AM USING A DAEWOO REFRIGERATOR. THE UPPER CHAMBER OR THE FREEZER IS VERY COLD BUT THE LOWER CHAMBER IS NOT COOLING . WHY IS THAT SO?
Hello Nickel129,
I understand that you are having a problem with the refrigerator. The freezer is cooling just fine however, the fridge is not cooling enough or at all.
1. Check to see if you here the fan in the back of your freezer compartment turning.
a. if you do not here the fan then you need to replace it.
1. Unplug unit (fridge)
2. Remove the screws holding the bottom (if any) and the back cover.
3. Locate the fan and remove the wires
4. unbolt the fan and remove the fan blade (some new motors do not come with the blade)
5. Purchase a new motor at a local hardware/appliance store
2. If the motor is running you need to check the air tunnels (pasages in the frezzer)
a. Remove the covers in the freezer as above. There will be one, two or three holes that go thru the bottom and into the fridge. If these holes are full of ice defrost (w/water, hair dryer, etc.) so that air can pass thru the holes.
The above should help you to fix your refrigerator.
Thank you for choosing Fixya.com for your questions
Justin
Mar 19, 2011 | Refrigerators
Fridge troubleshooting
Pull the refrig out , and remove the bottom panel covering the compressor , and make sure the fan , cooling the compressor , is working . The blade could have an obstruction . If the fan isn't turning , replace the fan motor . Also , make sure the bottom coils are clean of dust , lint , pet hair , etc .
Dec 08, 2009 | Daewoo Refrigerators
Freezer not freezing, fan in rear bottom of unit not running, condenser extremely hot to touch. ge gdl20kcsabs
Hi, If the compressor is running but the fan is not, you will need to replace the fan motor. First make sure that there is nothing stopping the fan blade.
If you have a window or box fan, let it blow on the compressor to cool it down. This will help you get by until you can replace the condensor fan motor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Refrigerators
Daewoo rotating base
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find parts.
May 24, 2009 | Daewoo KOR-630A Microwave Oven
The fan blades under the motor are broken i like my dirt devil triangle please help fix it.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=758276
Generic problem for all Vacuums
Posted by roadrunner19 on Jul 08, 2008
The fan blades under the motor are broken I like my dirt devil triangle please help fix it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Changing the fan should not be a problem; it happens every so often if you pickup something big and the plastic fan breaks. The cost to repair is about $10.00 to $20.00 plus labor and you can repair it yourself if you are handy or take it to a local vacuum cleaner dealer in your area and they can perform the fan replacement. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 08, 2008 | Vacuums
Refrigerators Logo
Top Daewoo Refrigerators Experts
Lawrence Oravetz
NOEL
NOEL
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
