Question about Canon Cameras
Canon ixus 330 zoom lens 3x 5.4-16.2mm1:2.7-4.7 download drivers
Posted by Bushfinders Safaris on
Tony Parsons
  • Canon Master
  • 6,370 Answers
Feel free - we won't prevent you.
Posted on Feb 13, 2020
5 Related Answers
Anonymous
SOURCE: lens stuck in the out position
nkkabra - how do you reload the firmware?
Posted on Dec 12, 2007
Anonymous
SOURCE: canon ixus 75 digital camera reset?
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
Posted on Mar 23, 2008
Anonymous
  • 489 Answers
Hi
What you are seeing is just an error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Posted on Apr 14, 2009
Anonymous
  • 2761 Answers
SOURCE: how to restart Canon IXUS 70
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
Kiran Anto
  • 420 Answers
SOURCE: Canon Ixus 900 Ti ~ Lens error Restart camera
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
I have just purchased a canon eos 600 digital camera.efs 18-135mm lens All excited.\r\nBought it home and on autofocus can't zoom the bird on the dam up very close? I can look through my point and...
Your not doing anything wrong, your Panasonic probably is using digital zoom (which is basically just cropping the picture imitating zoom). Your eyes sees similar to a 50mm lens so your 135mm lens is less then 3x zoom.
Do not be discouraged you will soon learn your cameras strengths and weakness.
Good Luck
How do you activate the digital zoom on a canon sd790 is
The digital zoom engages when you have reached the 3X manual zoom point, if you keep pushing the zoom button the camera will switch to digital zoom.
Canon ixus 70 all showing a fuzzy dark spot??
clean the lens,get it serviced the lens as well as CCD.
Canon IXUS 330 not recognized by Windows 7
Try not to connect at front usb. Only back USB (due to lack of power in it)
I'm having problems with I focus the camera out. It becomes burrie
The camera has limited ability to zoom out. I believe you have a 3x optical zoom, and a 7 x digital zoom. Once you go beyond the optical zoom, the camera attempts to digitally render the zoom which can cause pixalation, or bluriness. This should never be an issue inside the optical zoom range as the image is going directly through the lens.
Canon ixus 75 digital camera reset?
Hi
Thomas
Canon A630 lens will not zoom
The Gears for zooming are damaged i suppose ...... its complicated to open the lens as there are many components attached ..... Get it repaired from a repair man
Lost lens for digital camera
Its probably going to be cheaper to get a new camera with parts and labor. You could check at Best Buy.
Cameras Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
