Question about Hardware & Accessories
HOW dO i OBTAIN tIMER INSERTS - Hardware & Accessories
Posted by Mario on
Obtain a new cord for a 7 litter personal Fridge/Warmer?
Home Depot or Lowe's will have replacements, or find one online. These things are usually standard items.
Oct 08, 2014 | Heating & Cooling
Paragon Model 632-00 Manual
Copy following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#632
632-00 is 120Volt defrost timer. Electric heat defrosting with fan delay.
Hot connects to terminal 4
Neutral to terminal 6.
One wire from Fan, compressor, heater each connect to terminal 6, and other wire connects to one of the other terminals depending on electric heat, hot gas, or water spray defrost
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 24, 2013 | Paragon Hardware & Accessories
How does one replace front strut inserts on an 89 volvo 780?
GO TO A PRTS HOUSE THAT HAS INSERTS IN STOCK AND SEE WHAT KIND OF LOCK INSERTS USE. 89 PROBABLY USED INSERTS
Mar 02, 2013 | Cars & Trucks
There is a silver pin that fits into the periphery of the timer. I think this trips the smaller dial to rotate. If the sprinkler is set to go off at 4am, where should I place this silver pin for it to...
You have Intermatic sprinkler timer.
The silver pin inserts into the yellow dial at 12:00 midnight, and it rotates the skipper wheel.
Skipper wheel is necessary only if you want to skip certain days of the week, otherwise the timer cycle repeats each 24-hour period.
To skip a day, the skipper pin is pushed down for that day. Leave skipper pin up for days you want to water.
Open following links for more information:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Jun 24, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Where can I purchase the trip inserts for this product
You posted under Intermatic or Malibu power packs:
For full information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips: Including order form and direct link for ML series black and red trippers
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Nov 09, 2010 | Malibu ML200RT - Low Voltage Power Pack...
I have dryer whirlpool mod. LER4634EQ2, all time is on, don't stop, the timer don't run
The timer will almost certainly be the problem. Very possible the timer drive motor is faulty. Spares for whirlpool are difficult enough to obtain, so i would suggest a new timer as it would be easier to get than a timer motor.Very easy to replace as the timer is normally modulated. (pull wiring plugs out then simply push back in onto new timer).
Sep 28, 2009 | Dryers
Eddie Bauer mirror replacements
is it an aero mirror with no arms?
Or a trailer tow mirror with arms?
The glass is repalceable. It is mounted on a center post with a ball on it. The mirror has a socket on the back center.
It also has 2 jack srews (plastic) that go into the tiny motors that move the mirror. You can push and pull on the glass and they will retchet, it won't hurt them.
You have to pop the mirror off the ball.
It helps to heat the socket with a hair dryer to put the new one on.
Please rate as fixya if this solves your problem.
Glass — Outside Rear View Mirror
Removal
  1. Remove the mirror glass.
    1. Position the mirror glass to obtain a gap at the outside edge of the mirror.
    1. Carefully pry the outside edge of the glass away from the mirror housing.
d6ec385.gif Disconnect the electrical connector
Connect the electrical connector
NOTE: Engage the center pivot before the four inserts.
Install the mirror glass.
  • Engage the center pivot and the four inserts
Mar 10, 2009 | 1997 Ford Expedition
Hardware & Accessories Logo
89 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
