Question about Video Cameras
Vixia HF G20 dual Memory Cards - Video Cameras
Posted by Manny Perez on
2 Related Answers
old marine
old marine
  • 2346 Answers
SOURCE: where is the serial number?
Open the LCD, and you should see a "Batt Release" lever on the body. Slide this lever to the front and remove the battery from the rear of the camera (it slides down). The serial number is a ten or twelve digit number on a plate beneath the battery.
Posted on Feb 12, 2010
alexander404
alexander woolfolk
  • 276 Answers
SOURCE: how do i switch from
Press FUNC. (lower left LCD) , MENU, MEMORY OPER. MEDIA: MOVIES, then select the media you want to use. FUNC.
Posted on Apr 27, 2011
Tip
Convert Canon VIXIA HF S21/HF S200/HF20 AVCHD MTS/M2TS Files to iPad
Canon Vixia HF camcorders are becoming more and more popular among people who want to capture movies and movies of their daily life and interesting moments. Most Canon Vixia HF series Camcorders store video in AVCHD .mts file format that is a high definition video format. Take Canon Vixia HF S21 as an example, Canon HF S21 stores video in AVCHD MTS file format with MPEG-4, AVC/H.264 as video codec, and the 64GB internal flash drive enables long time video recording for more than 8 hours with Full HD 1920x1080 recording at FXP profile. It enables double slots for SD memory cards. (Some of Canon HF series and Canon VIXIA HF series camcorders are compatible with Mac, see at iMovie '09: Camcorder Support )<br /> iPad, as the newest tablet computer of Apple, offers you the best way to experience the web, email, photos, and video. However, if you want to enjoy videos shot by Canon Vixia Camcorder on iPad, maybe a little difficult for you to directly import Canon VIXIA AVCHD mts files to iPad, for iPad supported video formats are H.264, MP4, MOV. So you need to transfer Canon Vixia HF video files to MOV, MP4 or H.264 for iPad firstly, then you can import converted AVCHD MTS files to iPad and play them on iPad. <br /> Doremisoft Mac Canon VIXIA HF to iPad Converter is the best software to convert Canon VIXIA AVCHD MTS/M2TS to iPad MOV/H.264/MPEG-4, etc. It also can transfer AVCHD camcorder and camera video to other popular video formats including AVI, WMV, M4V, 3GP, 3G2, MPG, SWF, FLV, DV, MPEG-1, MPEG-2, MKV, H.264/MPEG-4 AVC, MPEG-1, MPEG-2, MPEG-4, MP4-Xvid, etc in order that you can import these AVCHD MTS/M2TS files to iMovie, FCP, FCE, iDVD, iPhone, Apple TV, iPod, PSP, BlackBerry, etc. <br /> Now, tutorial for you to convert Canon VIXIA HF AVCHD MTS files to iPad step by step as follows:<br /> Step1: Install and Launch Doremisoft AVCHD Converter for Mac<br /> Step2: Add Canon VIXIA HF Video Files<br />Click "Add File" to upload Canon VIXIA AVCHD MTS/M2TS files to Mac AVCHD Video Converter. You can add several videos one time.<br /> Step3: Select Output Video Format for iPad<br />Click "Profile" to open the Profile drop-up list to choose MOV, MPEG-4 or H.264 for iPad on Mac. And you also can set output video format for Mac, iMovie, Quicktime, iDVD, iPod, iPhone, etc.<br /> Step4: Convert Canon VIXIA HF AVCHD MTS/M2TS for iPad<br />Click "Start" to convert Canon VIXIA HF AVCHD video to MOV, H.264 or MPEG-4 for iPad. After conversion finished, you can watch and share converted Canon VIXIA HF videos on iPad.<br /> Related: How to Convert and Import Canon VIXIA AVCHD MTS/M2TS Files to FCP for Editing?<br />How to Convert and Edit Canon VIXIA HF series to iMovie?
on Nov 19, 2010 | Computers & Internet
Tip
Import Canon VIXIA Series Video to FCP and Edit Canon VIXIA HF Video in FCP
Most Canon VIXIA HF series and other VIXIA series camcorders record video in high definition using a special codec (compression/decompression) called AVCHD, for example, Canon VIXIA HF11, VIXIA HF R11, VIXIA HF200, VIXIA HF R100, etc store videos in HD format using AVCHD compression and the files have MTS extension. For Mac users, it's virtually impossible to edit Canon VIXIA AVCHD footage natively in FCP due to different video codec and taking large space.
But also some of Canon VIXIA HF series camcorders can support iMovie' 09 or iMovie' 11. You can check the list of Canon VIXIA HF camcorders compatible with iMovie' 09 as follows:
Canon VIXIA HF M30, VIXIA HF M300, VIXIA HF R100, VIXIA HF R11, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200
So if you would like to edit Canon VIXIA AVCHD video in FCP, you need to convert these AVCHD MTS files to FCP supported video format like MOV, MP4, DV, then you can import them to FCP for editing.
Doremisoft Canon VIXIA to FCP Converter is specially designed for Mac users to convert camcorder video like Canon VIXIA video, Sony HDR video, Panasonic HDC video, etc to Final Cut Pro MOV/MP4/DV. It also supports converting video including MTS/M2TS/TS/TRP(AVHD H.264, VC-1, MPEG-2 HD), MKV, etc to MOV, MP4, AVI, M4V, 3GP, 3G2, MPG, DV, MPEG-1, MPEG-2, WMV, etc.
Doremisoft Mac AVCHD Converter not only have the ability to convert HD videos to SD (Standard Definition) format, but also the ability to convert SD to HD which contains MPEG2-HD, MPEG4-HD, H.264-HD and more. More editing functions of Canon VIXIA to FCP Converter you can see edit AVCHD MTS/M2TS Files on Mac OS.
Before you import Canon VIXIA videos to FCP to edit them, the following easy guide can help you convert Canon VIXIA AVCHD MTS/M2TS files to MOV, DV or MP4 for FCP.
Step1: Add Canon VIXIA Video Files
Click "Add File" to upload your chosen Canon AVCHD MTS, M2TS files to Canon VIXIA to FCP Converter after you lauched it.
Step2: Set Output Video Format for FCP
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4 or DV as output video format for FCP on Mac OS. And you also can convert Canon VIXIA MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, etc.
Step3: Convert Canon VIXIA Video to FCP
Click "Start" to convert Canon VIXIA videos to FCP, and you can edit your these converted AVCHD files with FCP on Mac OS X after converting finished.
Related: How to convert AVCHD(MTS,M2TS) to DV on Mac?
How to Convert and Edit Canon VIXIA HF200, VIXIA HF R11, VIXIA HV30 Video to iMovie?
on Nov 17, 2010 | Computers & Internet
How do i switch from internal memory to the sd card on my canon vixia hf r10?
Apr 27, 2011 | Canon Vixia HFR10 Silver Dual Flash Memory...
I lost the manual for the comcorder canon vixia HF R11, there is any way to find it on line?
You can download and print the instruction manual in PDF format by clicking these links:
Instruction Manual
Quick Guide
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 06, 2011 | Canon VIXIA HF R11 Dual Flash Memory...
Tip
Convert/Import, Edit Canon VIXIA HF Series Video to Mac, iMovie, Quicktime
Canon VIXIA Camcorder has a good reputation for its small size, recording video in full HD quality, lightweight, etc. Just like popular Canon FS series camcorder, Canon VIXIA HF series Camcorder is a large family including VIXIA HF R-series like VIXIA HF R10, VIXIA HF R11, VIXIA HF R100; VIXIA HF M-series such as VIXIA HF M30, VIXIA HF M31, VIXIA HF M300; VIXIA HF S-series like VIXIA HF S10, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200, and some other popular VIXIA types such as VIXIA HF10, VIXIA HF100, VIXIA HF20, VIXIA HF200, VIXIA HG21, VIXIA HG20, etc.
Most of Canon VIXIA HF series camcorders record videos in AVCHD MTS files. If you want to share these AVCHD MTS files with family or friend on Mac, you may cannot directly playback these MTS videos with your Mac, iPad, iPod, iPhone, or Blackberry. If you would like to customize Canon VIXIA HF video on Mac, you may cannot directly edit MTS videos in iMovie, FCP, FCE, etc. What should we do about this? The best solution is to transfer Canon VIXIA HF video to Mac supported video format such as MOV, MP4 that are aslo for iPad, iPod, iPhones, Blackberry, PSP, etc.
AVCHD Converter for Mac is the best choice for you to convert Canon VIXIA HF video to MOV, MP4, AVI, 3GP, MPEG-4 for Mac so that you can import these AVCHD MTS/M2TS files to iMovie, iTunes, iDVD, FCP, FCE etc for editing. Besides, this Canon VIXIA Video Converter for Mac also has powerful editing function like trim video length, crop video, set video brightness, contrast, and saturation, and customize video/audio output settings, etc.
Now, easy tutorial for you to convert Canon VIXIA video to Mac OS step by step.
Step One: Import Canon VIXIA HF Video to Mac AVCHD Converter
Firstly, you need to copy your Canon VIXIA video to Mac and launch AVCHD Converter for Mac, then you can click "Add File" to upload your AVCHD MTS files on Mac.
Step Two: Set Output Video Format for Mac
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS.
Step Three: Convert Canon VIXIA Video to Mac
Click "Start" button to convert Canon AVCHD MTS files for Mac. After conversion finished, you can edit your converted MTS, M2TS files with iMovie, FCP, FCE, iDVD, etc as you like.
on Oct 13, 2010 | Computers & Internet
Tip
Put and Play Canon HF S21 HD 1920x1080 AVCHD MTS on iPad Canon Vixia HF S21 is...
Canon Vixia HF S21 is the new AVCHD camera in 2010 for capturing Hi Def 1920x1080. The 64GB internal flash drive enables long time video recording for more than 8 hours with Full HD 1920x1080 recording at FXP profile. It enables double slots for SD memory cards.
The video captured with Canon HF S21 is stored in AVCHD .mts file format with MPEG-4, AVC/H.264 as video codec, and Dolby Digital 2 channel (AC-3) as audio codec. If you get the with optional Canon SM-V1 5.1-Channel Surround Microphone, you can get Dolby Digital 5.1-channel for the audio.
To transfer Canon Vixia HFS21 AVCHD to computer hard drive:
You can use the bundled Pixela ImageMixer 3SE Video Editing Software, and it is easy to transfer Vixia HF S21 AVCHD movies onto computer hard drive with this software. If you are using Mac computer, you can also use iMovie to download videos to Apple hard drive. Just connect the camcorder to iMac/MacBook Pro with Mac OS X like Snow Leopard, and HF S21 could be recognized by iMovie for loading videos.
To put and play Canon HF S21 AVCHD videos on iPad:
Even though iMovie mentioned above could recognize Caonon HF S21 for loading videos, there are also problems for importing Canon HF S21 .mts to Final Cut Pro (FCP) or Final Cut Express (FCE), even iMovie. Aunsoft MTS/M2TS Converter for Mac is the recommended Mac Canon HF S21 MTS to iPad converter for you to easily edit Canon HF S21 videos and transfer edited video to iPad.
Below are the simple steps for transcoding Canon HF S21 to iPad.
Step 1. Load Canon HF S21 video to Aunsoft MTS/M2TS Converter for Mac.
After transferring Canon HF S21 AVCHD videos to Apple hard drive, run Aunsoft MTS/M2TS Converter for Mac as Canon MTS converter and click the "Add" button to load .mts videos.
Step 2. Edit Canon HF S21 MTS videos.
Select the video clip and click the "Edit" button to trim and crop videos, to flip video, adjust brightness and contrast.
Step 3. Choose iPad HD output format.
Click the "Format" option and choose iPad > iPad HD Video(*.mp4), and the Mac Canon MTS to iPad converter will convert AVCHD Hi Def 16x9 to 720p MP4 videos for iPad.
Step 4. Convert Canon HF S21 MTS to iPad.
Click the convert button under the preview window, and the conversion from Canon HF S21 MTS to MP4 for iPad starts immediately.
After the conversion, connect iPad to iMac/MacBook Pro and sync the editing videos to iPad. It is that easy to transferr edited video to iPad. Give it a try and enjoy AVCHD videos on iPad.
on Jul 29, 2010 | Cell Phones
Where is the serial number on my Canaon Vixia HFR10?
Took me forever to figure this out as well. It's the 12 digit number inside the white square on the battery cover on the bottom of the camera. The trick is to NOT include the two letters after the twelve numbers.
Dec 23, 2010 | Canon VIXIA HF R10 Dual Flash Memory...
Where is the serial number? Canon VIXIA HF S10 HD Dual Flash Memory with 32 GB Internal Memory and 10x Optical Zoom
Feb 12, 2010 | Canon VIXIA HF S10 Camcorder
Video Cameras Logo
Top Video Cameras Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Video Camera Expert? Answer questions, earn points and help others
