Question about Refrigerators
I have an iceomatic ICEU220HA that is brand new. It will drop the first batch of ice and the push rod keeps going in out and and the back tray keeps heating. It will not go into the freeze mode
2 Suggested Answers
Anonymous
SOURCE:
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Ice will no longer drop to ice tray
You havge a bad mold heater in the ice maker.
Posted on May 20, 2009
Cooling capacity of ICEU220HA1
Do you mean the Ice-o-Matic ICEU220HA1? I can't find a listing for this model specifically. However, I found data on the ICEU220 on the manufacturer's support site: https://www.iceomatic.com/servicesupport . Using the drop-down menu on the left and then pressing search, I found the manual and service documents here: https://www.iceomatic.com/servicesupport/select?sku=ICEU220%2F226%2F225 . The direct link to the manual is https://iom-stage.azurewebsites.net/getattachment/3d34634e-51f8-40c9-bc7d-ca0c4e6af435/ICE-Install-Manual-11-2016-(1) . The manual indicates that the A means that this is an air-cooled ice maker and the 1 indicates the design version.
The specifications sheet has more information. The ICEU220A (air-cooled) uses about 4,609 BTU per hour (depending on the air and water temperature). It uses 8.8 kWH of power to make 100 pounds of ice. The specifications sheet is available here: http://iceomatic.kclcad.com/Mobile . Scroll down the left column to find the ICEU220HA. The direct link to the specifications sheet is currently http://iceomatic.kclcad.com/ViewFile/IC/ICEU220HA/SpecSheets/ICEU220-Cube_1020 , according to my browser history.
I hope this helps.
Aug 14, 2018 | Heating & Cooling
Whirlpool bottom freezer ice maker will only make ice if I pull and then replace the ice container, why?
The ice maker works off a timer that controls the discharge of ice, water fill, etc. Right before the tray discharges ice it is heated slightly so the ice is just slippery enough to discharge the ice. Unfortunately, now and then (for us) a chunk of ice remains in the tray. This chunk prevents the blades from rotating and eventually you have a mass of new ice with the blades in the wrong position. The blades have to be in a certain position for the heater to kick in. You are stuck with cracking up the ice stuck in the tray to get the blades to rotate again. We have an Electrolux ice maker but this problem occurs periodically. The root of the problem is it's failure to heat up the ice tray adequately to discharge ALL the ice. One thing to remember is that next time this happens you have to manually break up the ice in the tray and push the timer advance button until the 2 set of blades are fully closed (hidden) and at 90 degrees. From that point on at least the ice maker can start making more ice.
Aug 23, 2014 | Refrigerators
What can i do or do i have to bring it in for repairs?
There are three easy things to look for. First in the center of the ice grid there is a plunger rod that pushes the ice out. Need to make sure that is all the way in on start up. Second the ice curtain has a tab on the top right that has to be behind a metal switch tab that sticks through the side on the unit. Third on some units right in front of the water trough is a thin metal rod, that is actually the bin thermostat. If there is any ice laying on top of that rod it will shut the unit off at a full bin.
Apr 27, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Iceomatic
Make sure you have power and water...be more descriptive if there is any more to it.
Dec 17, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
My iceomatic ice machine is not producing ice. There is ice frozen to the grate and water is not running
Could be a bad water solenoid. Could also be because it needs to be cleaned. If there is ice stuck to the evaporator, the hot gas bypass is not working. Try cleaning the unit first.
Nov 17, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
May 04, 2009 | Sub-Zero 642
Kenmore 253.54703405 ice maker does not reset
a gear under the cover turns the arm,i think you should find a appliance part store in your area and replace,around $50 for brand new one,thanks-mike
Jul 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
