Question about Refrigerators
Where can I get a owner Manual for a 70 litre Kellermann campng freezer can't set my tempreturs Many Thanks Fred
Posted by Fred on
Freezer side is fine but fridge side wont get below 39 degrees
Nominal tempreture for your refrigerator is 36-38. on the Freezer the tmpreture should be between 0-2. One of the first things to check is on the freezer side is there any frost or snow build up on the rear wall of the freezer. If there were this is termed as a defrost issue. If you do have this issue with frost build up message me back and I will instruct you how to repair this issue. Another thing to check is if the evaporator fan inside the freezer is blowing the cold air into the refrigerator. The Freezer section is the only area that produces the cold tempreture a fan blows the cold air off the evaporator coils through a damper door that opens and closes depending on the tempreture the refrigerator side is set to. Also check the damper door for any ice build up as well this would cause the door not to open and close and remain in a stuck postion. This would cause inadequate tempreture in the refrigerator side as well. If you have any questions or need any schematics or step by step instructions message me back the model number of your unit and I will provide these and answer any further questions you may have. I await your reply
Thank you
Rick
Jul 12, 2012 | Frigidaire Refrigerators
CANNOT SET TEMPERATURE
Nominal tempretures for the refrigerator side are 36-38 degrees. Nominalk tempreture for the freezer section is 0-4 degrees. Your main board that controls your entire refrigeration can be found on this diagram as 1-5 http://c.searspartsdirect.com/lis_png/PLDM/50039314-00004.png
What tempreture are you trying to achieve? By setting the unit colder you also cause the unit to work harder as well shortening the lifespan of your refrigeration compressor as well as other key parts that perform to make your unit produce cold. Some key things to look for are any type of freeze up on the rear wall of the freezer which is termed as a defrost issue and if you do have this issue message me back and I can instruct you to solve this situation. I await your reply
Thank you,
Rick
Jul 01, 2012 | Samsung RB215LASH
Hi my whirpool oven is stating F 03 what do i have to do? Thanks
Usually the F-03 error code means you have a bad oven tempreture sensor. To test the tempreture sensor you would use a multimeter set to ohms. At room tempreture the sensor should read between 1000-1100 ohms any less then this and you would replace the oven tempreture sensor in the unit. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s I also looked afterwards in your service manual and the F-03 error code does refer to the oven tempreture sensor
Sep 13, 2011 | Whirlpool RBS275PD Electric Single Oven
What temp should frig be set for and what temp for freezer?
Nominal tempretures for freezer are 0 degrees and for a refrigerator are around 37-38. If you have any further questions message me back. Thanks Rick
Sep 10, 2011 | Bosch Refrigerators
Ive forgotten which way the dial goes...is it min or max to make the fridge cold? the freezer part is working however
on any refrigerator or freezer it should be set in the middle whereas if your unit said 0-9 you would set your unit to 5 or if it just says min and max in between these would be the the best. optimum tempretures are at 37-38 in your refrigerator and 0 in your freezer if you have any further questions message me back and please remember to rank how this opinion has helped it allows for me to help others in similar situations Thanks Rick
p.s it is also best to keep two manual thermometers in both the freezer and the refrigerator at all times this way you always know your exact tempreture
Mar 20, 2011 | Refrigerators
The freezer is geting high temperture, it could be set down.
find the adjustment knob, set it to a desired tempreture and allow 24 hours for adjustments
Mar 02, 2011 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Frost free freezer frosting up
check for the tempreture adjustment knob in the refrigerator section as it might accidently have been turn to extreme high ...setting the refrigerator tempreture to very low can cause this problem in the frezer section try turning the knob to medium or tempreture according to the outside tempreture....
Jan 21, 2011 | Kenmore Refrigerators
How to set tempreture (no manaul ) has digital read- out an menu
push set or hold set button and rise or dawn temperature, tell me more of your freezer, in this world are thawsens of thowsens of models, nobody can help you if you will not provide all info.
Feb 21, 2010 | Refrigerators
Need a owners manual for a 1995 Plymouth mini-van. Recently bought this van which did not have a manual. Would surely appreciate any help you could provide. Thanks alot, Fred.
http://www.pdfoo.com/result-1995-plymouth-grand-voyager-owners-manual.html
hope this helps! but please before posting on forum google the problem.
Feb 17, 2010 | 1995 Plymouth Voyager
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
