Question about Samsung Office Equipment & Supplies
Https://eu.community.samsung.com/t5/Cameras-IT-Everything-Else/Samsung-SCX-3200-Printer-Double-Printing-Problem-Software/td-p/260539
Posted on Feb 12, 2020
SOURCE: Problems with Samsung SCX-4216F All-In-One Laser Printer?
SCX-4216F could receive fax, but didn't print out faxes. Can anybody help me with this?
Posted on Mar 11, 2009
SOURCE: Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
Posted on Jul 03, 2009
SOURCE: how to reset samsung scx 4300 printer cartridge
you can not reset this chip change it you must be buy a new one cartridge
Posted on Nov 04, 2009
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Dec 24, 2009
SOURCE: Samsung SCX 4200 MF Printer Problem
it seems printer try to download firmware from your computer
Maintenance > Of clear Of setting > Of all Of setting [OK]3.
In the service menu (TECH MODE):MENU> Of data Of setup > Of clear of count > Of clear Of all CNT
MUSTAFA BULENT KILIMCI
YUNUS COMPUTER CEO
COMPUTER EXPERT
e-mail & msn : address [email protected]
Posted on Jan 07, 2010
Feb 28, 2016 | Samsung SCX-4321 All-In-One Laser Printer
Sep 29, 2014 | Samsung SCX-4321 All-In-One Laser Printer
Apr 20, 2014 | Samsung SCX-4300 Monochrome Laser...
Dec 16, 2013 | Samsung SCX-4321 All-In-One Laser Printer
Oct 20, 2013 | Samsung SCX-4321 All-In-One Laser Printer
Dec 04, 2012 | Samsung SCX 4521F All-In-One Laser Printer
Dec 26, 2010 | Samsung SCX-4321 All-In-One Laser Printer
Jul 03, 2010 | Samsung SCX 4521F All-In-One Laser Printer
May 09, 2010 | Samsung CLP 300 Laser Printer
Nov 20, 2006 | Samsung SCX 4521F All-In-One Laser Printer
60 people viewed this question
