Question about Frost Refrigerators
Will frost affect eliminator power charger?I've been told this item can't be kept in car in case of freezing
Posted by carol on
govatir635
    Problem Solver:
  • 6 Answers
Start getting paid each month more than $17,000+ just by w0rking 0nline from home. Last month i have earned and received $18539 from this easy 0nline j0b. This 0nline j0b is just amazing and regular earning from this are just awesome. Start making extra dollars 0nline just by follow instructions on this website....HER
Heres what I do
... .............. http://www.jobs120.com
Posted on Feb 11, 2020
2 Related Answers
Anonymous
  • 4 Answers
SOURCE: lots of frost in freezer
check your seals on the door and see if any on the compartments are broken because if the door is broken to the compartment it could be that the the cold and warmth is mixing causing your freezer to frost up temp could also be to high check all
hope this help
Posted on Dec 12, 2009
ImJustAvg
  • 2006 Answers
SOURCE: frigidaire upright model ffu21k2cw1 frost on top shelf and not cooling properly
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/216802800en.pdf
Your unit is not self defrosting so I would suggest you do a manual defrost and see if it corrects the problem.
Also make sure that you have good air flow across the compressor.
Posted on Jan 02, 2012
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
Fridge freezing over
Improve the FixYa experience by voting.
There are two possible causes for you problem:
First. The defrost timer is probably loose internally. Replace it. If it occasionally malfunctions the defrost heater will not work which can be a cause for the evaporator freezing/frosting up.
My advice, replace the timer and you should eliminate the problem(s). This is a do-it-yourself that is in expensive and not difficult to do. You can get everything that you need at a local appliance parts store or check out Siemens parts on their website. CLICK HERE for the Siemens parts website:
Second possibility: The possible cause for the freeze up is that the coil is colder than it should be. There are several potential areas of concern that you might have experienced,
A faulty coil causes items in the crisper drawers to freeze. This is the most common problem I have seen with the Siemens refrigerator.
There may be an air flow problem if the drain assembly has iced up and ice is partially covering the air vent.
If necessary, turn the adjustable feet up or down so they contact the floor squarely.
If you've experienced leaking under your refrigerator, it may be caused by a condensation tube that doesn't drain into a pan or by a clogged freezer drain.
May 13, 2012 | Siemens Refrigerators
I have a Utilitech In Wall Digital Timer Lowes Item #: 141224 | Model #: LW60418, purchased from Lowes. I've lost the instructions and can't figure out how to set the timer after a power...
Open following link for Utilitec timer manual:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer should have a back-up capacitor so that programming is kept in memory during power outage.
Power outage is known cause of timer failure. When power turns on, the surge knocks out electronics.
People writing to fixya report electronic timers and electronic water heater controls stop working after power outage. Probably many other electronic devices are affected too, but that would be out of my specialty.
Troubleshoot says 'in case of operational failure, press reset button to clear all settings and restart.'
If timer has failed, buy another from Lowes and return defect in new package.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a frig model 3639656686 the freezer works great. the frig stays warm. I have replaced the control and stat for the self defrosting unit the only other thing is the heater. The coil part will freeze...
A refrigerator not cold enough is a hassle, because you are at risk of spoiling the foods you store in there. Most often, this problem is caused by something easy to fix. 1. Faulty Door Gaskets
The door gaskets in a refrigerator ensure a sealed closure every time you shut the door. Torn or loose gaskets on the door of the refrigerator can result in a leak in the cold air. As a result, the refrigerator is warmer. Repetitive and frequent opening and closing of the refrigerator is also a possible cause, because the warm air from outside replaces the cold air in the refrigerator every time you open it. 2. Dirty Condenser Coils
Dirty condenser coils can result in improper functioning of the refrigerator. These coils are located on the back or the underside of refrigerators. If you find this to be the cause of the problem, unplug the refrigerator before you attempt any cleaning. 3. Frost-free Feature not Working
If the frost-free feature fails, it causes a buildup of frost around the evaporator coils in the freezer. This causes a malfunctioning of the evaporator fan that blows cold air around. The fan can also be damaged if it hits the frost. 4. Faulty or Incorrect Temperature Control
A faulty thermostat can lead to a refrigerator that is not maintaining the desired coldness. Check for this problem and also ensure that the temperature is set to the correct level. Normally, refrigerators are set to a temperature of about 0°C, whereas the freezer sections are around -17°C. 5. Inadequate Air Flow inside Refrigerator
A refrigerator that is loaded with too many food items can fail to maintain an adequate level of coolness across all the items kept in it. The surface items tend to be colder, and the items underneath do not become as cold. A refrigerator that has very few items in it can also fail to function efficiently. Try to ensure that your refrigerator has enough food in it at all times, but is not so loaded that the air flow gets constricted. 6. Vents between Freezer and Refrigerator Clogged
The vents between the freezer and refrigerating section blow cold air from the freezer across to the refrigerator. If these vents are clogged with ice, the air is blocked and the refrigerator does not cool down. If this is the case, you can unplug the refrigerator, wait for the ice to melt and then connect it back to the power supply. 7. Faulty Door Switch
The door switch is found on the bottom of refrigerator doors. It turns off the light in the refrigerator and resumes cooling action when you close the door. If this switch is not functioning properly, the refrigerator will not be cold and it will also be affected by the heat of the interior light. 8. Refrigerant Leak
A refrigerant leak is very unlikely. This problem can cause malfunctioning of your refrigerator. If you suspect this to be the cause, contact a service technician.
Hope this will help out....
Aug 27, 2011 | Kenmore Top Freezer Refrigerator
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
All of a sudden freezer side is cold but not freezing, unit is about 9 years old
Hello, there
8. Refrigerant Leak
Hoping this will help in solving the problem....
May 09, 2011 | Whirlpool GS5SHAXN Side by Side...
I have a whirlpool side by side (GD5LHG) that quit cooling and freezing. both fans are working. is it the compressor?
8. Refrigerant Leak
Good luck....
Aug 08, 2010 | Whirlpool GS6NBEXR Side by Side...
My Hp is freezing when i move it and the whole screen goes blank or a certain colour. Sometimes i dont even have to move it and it freezes. I was told this could be a motherboard problem. Furthermore it...
if your having problems with the laptop charging and turning on plus the freezing that is going on then its going to be a motherboard issue cause the power connector is a part of the motherboard and the battery gets its power from the motherboard.
If your notebook is still covered under warranty then call HP and get it serviced otherwise you'll have to buy the motherboard which looks like this and this also has the part number so you can do your own shopping around as well:
http://laptopparts.vivotechnology.net/items/item.aspx?itemid=1367281
Jan 23, 2010 | HP Compaq NC6400 Business Notebook
Kenmore Upright 13 cu.ft freezer- uneven freezing
no it sound like there is a problem with the seal system where the freon is kept this model does not have a fan because is the shelves get frosted so there is a leak or restriction so try calling a tech but i would just buy a new if i was you since to fix will cost about the same
Nov 08, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrigerators Logo
Top Frost Refrigerators Experts
jdthefixer
RudeRude
john h
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
