At home or work.? or starbucks????? locations matter
as does how and what is your ISP connections.???????
This lame error on many PCs, none stated by you.
means really the PC to router to web connections are lost,
or the web is dead. www, is dead.
first rest the router and ISP modem ,no ISP told by you.
IF all PCs at home fail to get web.
then the problem is router or modem
if only ONE PC fails that means it is only tHIS PC failing.
Is this windows? , that too not told.
if yes,then the task bar has NETwork internet access icon on right side of tray bar. (look)
if dead that means LAN is dead. fix that.(ASK)
aRE You using wired eithernet to router
from PC or wifi, that too not stated.
so there is no real answer lacking all facts above not told.
if the task bar icon showS net IS up.
then try a different browser. try firefox.
if that works the other unstated browser has proxy turned on so turn that off in there.
OR IF AT HOME CALL YOU ISP AND THEY MAY WALK YOU THROUGH ALL THIS,
SOURCE: dns error!!!!
lol i have a solution to my own problem buy a router man ull never have this problem again atleast u shouldnt plug it up and press wpa personal with ur own wpa key and i pretty much say ull be problem free
SOURCE: dns server error
is it an older game?
if it is then its because the website group hosting that game has stopped because not enough people play to keep the dns system up
SOURCE: E-mail error #802
The code is the malfunction on the DC power fan parts.Clean,vacuuns the fan.
SOURCE: DNS 807101102. An error occurred during
if wireless how much % of signal do you have?, does it do it all the time? what router are you using? some routers have to be set diferently than normal in order for you to be able to play. change your ps3 IP adress one number up exanmple if its 192.168.10.172 change it to 192.168.10.173 or try this link if you have a linksys router it seem common for that router to get that error-http://boardsus.playstation.com/playstation/board/message?board.id=psnetwork&thread.id=116102
