Question about Maytag Washing Machines
MAYTAG BRAVO XL WASH VERY SLOW BUT IS ABLE TO SPIN FAST ON SPIN CYCLE
Posted by YOLI on
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
Posted on Oct 10, 2007
Anonymous
  • 146 Answers
SOURCE: Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Posted on Oct 31, 2007
the dr
joey shearer
  • 447 Answers
SOURCE: Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Posted on Jan 15, 2008
Anonymous
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
Doug Camburn
  • 122 Answers
SOURCE: Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
Posted on May 22, 2010
Testimonial: "Thanks, I looked at the belt and it looked loose. While running it I pulled the motor to tighten the slack but it didn't speed up. Could the belt still be bad? Are you referring to a bearing on the main spindle shaft? Or along the belt track? Thanks, David"
On a Maytag Maxima XL front load washer, please tell me on what cycle to wash a bathroom rug. zo vs
the heaviest cycle there is . but it sounds like the control board is not advancing the timer if it sits that long on one thing perhaps a call to a repairman is called for .
Jun 22, 2015 | Maytag Neptune MAH5500B Front Load Washer
Why does my maytag Bravo top load washer not drain or spin error code OL, if I change cycles to rinse and spin it drains
The controller unit has probably failed. This controls other items like drain pumps, heaters, motor etc. Because the machine can drain on a different cycle, the drain pump is fine. The cycle you use may be the only one the controller is broken for, try different wash/drain cycles. If you want to fix it you need to change out the controller, which is an expensive part compared to others.
Oct 17, 2013 | Saws
Washed cloths still dripping wet after wash cycle completed.
The Problem seems to be with the spin cycle, The cycle isn't spinning fast enough or the spin cycle is too short either way the whole thing can be repaired by trying another timer control.
Feb 11, 2011 | Maytag Washing Machines
Maytag top loading washer 1994 does not spin during rinse cycle
The problem will be the spinning coil is cut off or short circuited kindly replace the motor and check it
May 17, 2010 | Washing Machines
Bravo washer spin problem; lights flashing SD appears. called advised to wash clean cycle and use HE detergent.
the "SD" code is for suds, you are using too much detergent, you generally only need about three teaspoons of detergent, more for heavily soiled or larger loads, the HE detergent is a high efficiency detergent that is low sudsing, the wrong detergent can also affect the quality of the spin cycle.
Apr 07, 2009 | Maytag Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Maytag won't agitate during wash
sounds like you have a broken sety fo brake pads, just replaced a set today for same reason, open the lower acess panel and with a flashlight look into the bottom , your lookin for brake pads( theyre probably broken and laying under unit.)
Apr 28, 2008 | Maytag SAV4655A Top Load Washer
Won't agitate
well, you might have to get a new washer. It sounds like the control circut is going out and the door switch is also gone. it would cost about the same as a new washer. sorry.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Nov 21, 2007 | Maytag MAV7600 Top Load Washer
Won't spin fast.
sounds like motor control ..but three thing can keep it from not spinning .. Motor control- main control and or door lock... if just the spin cycle it may be the motor control..let me know what you find..
Aug 29, 2007 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
