Question about Refrigerators
Freezer stopped working. Everything is thawing.
Posted by Jerry Kassanchuk on
Attique-ur-Rehman
    Top Expert:
  • 2,677 Answers
Causes: If your freezer won't freeze, most likely the condenser coils are dirty which reduces the overall cooling capacity of the freezer. Evaporator fan motor is malfunctioning, and since it's in charge of circulating the air throughout the freezer, this will need to be resolved, pronto.
https://www.ahs.com/home-matters/repair-maintenance/is-your-freezer-not-freezing
Posted on Feb 09, 2020
5 Related Answers
Anonymous
SOURCE: frig working, freezer stops working, then starts working again
The computer control circuit board was found to have a burned out circuit. The board is on the lower back side behind a panel, easy to replace. Just need the proper model number to order the board.
Posted on Sep 08, 2008
Anonymous
  • 170 Answers
SOURCE: KitchenAid Side-by-side (ksrg25fkwh05) - Freezer not working
The odds are it is a circuit board problem...I had a huge Amana 27 cubic foot side by side and it did the same thing...I diagnosed the problem and replaced the circuit board ....which actually controls everything...one sure sign is to pull the unit out as the other person did and to access the back of the unit where the compressor is...(the comptressor should be on 85% of the tme....if it is not on and warm or hot to the touch then it is a circuit board problem....since compressors will continue to run if there is a defrost problem (most of them anyway), or an Ice build up, etc etc. I don't recommend a layperson trying to replace the circuit board (mine cost $115,) but if you do it is generally in the door mine was a long thin circuit board behind the fridge door handle. .P.S. the heat that the other person felt on the door and around the door seals is normal lots of people don't even know this heat strips exist until something haappens and they start feeling around...these heat strips are to prevent frost of ice build up where the door meets the fridge framd...which can happen due to the extreme temp difference between the two...(inside temp and outside temp).
I hope this has helped...good luck...Knowledge gives you a base from which to yield power over unscrupulous repairmen whop may try to take advantage of people.
Again ...good luck and let me know what happens.....Please rate me .....The Fang.
Posted on Mar 27, 2009
buddymcl777
Bruce McLeod
  • 67 Answers
SOURCE: Frig and freezer not cooling. Everything is thawing
1/ refrigerant leak or
2/ Defective thermostat / sensor or
3/ Burnt out compressor
Posted on May 01, 2009
Anonymous
  • 1136 Answers
SOURCE: freezer is thawing - water dripping -
Hi, if the clicking noise is coming from the back, it is the relay on the compressor. It os possible that the compressor is bad but, most common it is the relay.
Is this under 5 years old? (warranty)
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: refrigerator not cooling and freezer not freezing
The compressor start relay or start capacitor is defective and I will need to go through this in a step by step process until we locate the problem For now unplug the refrigerator to prevent compressor damage until we locate the problem. Let me know when you are ready. Sea Breeze
Posted on Jun 24, 2009
I have two door bottom freezer in my LG refrigerator...Freezer is defrosting its' contents..I lowered the temperature but it still persists...any solutions?
My bottom freezer LG is intermittently shutting down and thawing everything in the freezer (cooling stops in fridge part, too). $3,500 for a refrigerator that works only 18 months.
Mar 18, 2013 | LG Refrigerators
It might be the compressor making the noise.If it is,the compressor will start/stop frequently.This means that it is tripping on overload due to mechanical damage.Only way to solve this prolem is to replace the compressor (if the freezer is still in a good condition).
Regards
Andre Nagel
Mar 25, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
The freezer appears to be thawing even when shut all day.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 18, 2009 | Refrigerators
Freezer is thawing - water dripping -
Vic
May 30, 2009 | Maytag MTB1504A Top Freezer Refrigerator
Everything works but no water
Try turning down the freezer a little.
You can 'thaw' the water line in the door by hanging some towels in the freezer with the door open. Should thaw in a couple hours. At least this way you don't need to empty the freezer.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
Refridgerator and freezer stop cooling
inspect first the condenser at the rear or at the bottom back of the freezer. see if it is full of dirt and trash.
if it is, clean it and it could just be the problem.
if not, then observe the unit further, adjust the thermostat first to the coolest setting just to eliminate the problem with the thermostat.
keep me posted.
tnx 4 using fixya,
drcool
Nov 08, 2008 | Kenmore Refrigerators
Frig working, freezer stops working, then starts working again
Sep 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
