Question about AT&T Cell Phones
Need network unlock code for AT&T Galaxy S7 edge G935A for imei 353145678945615. Do anyone have
Posted by Mishal Malick on
Andrew Taylor
    Top Expert:
  • AT&T Master
  • 34,141 Answers
It can only be unlocked by AT&T as long as the contract has expired.
Posted on Feb 12, 2020
5 Related Answers
sumit kumar majhi
  • 110 Answers
SOURCE: i need the network unlock code for samsung SGH -E390
To unlock your samsung mobile,follows these steps
Do a custom reset:
*2767*2878# once this has finished rebooting turn the phone off.
Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter),
Turn on the phone - you will now see an "Insert SIM" message,
Now perform a full reset:
*2767*3855#
When the phone powers off, quickly push the SIM card fully in, and let
the phone power back up.
After you do the reset, check and make sure that your Network lock is active by pressing *#7465625#
If it isn't active you must use this code to reactivate it:
*7465625*638*00000000*00000000#
Then you have to deactivate the SP lock first. To do that you need to input:
*7465625*77*00000000*00000000# (this will reset the lock)
Then you enter:
#7465625*77*00000000# (to disable the SP lock).
Then you disable the Network lock:
#7465625*638*00000000#
The phone is finally unlocked.
Posted on Feb 16, 2009
SOURCE: t-mobile network unlock code lg kp100
You can try these codes with her phone, as its the only known process that can be found.
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
I can't promise it will work, but it's the only one my cell unlock software could come up with. Thank you for trying Fixya!
Posted on May 21, 2009
Anonymous
  • 22 Answers
SOURCE: i need an imei unlocking code
hi
unlock codes arethe very best and safest method to unlock your phone i for instance is abusiness traveler and i use an unlocked phone
so that i can use any country specific networks, i reckon i got unlock codes from this following link CLICK HERE and it workedperfectly well
Posted on Jul 05, 2010
Mike Wong
  • 10 Answers
SOURCE: how to unlock samsung galaxy ace GT-S5830D
you can unlock it via IMEI or USB. USB is more cheaper and faster. Read more at http://www.fastgsm.com/en/samsung/samsung/s5830d/unlock-code/unlocking
Regards,
Mike
Posted on May 14, 2012
asraful_cwbi
asraful_cwbi
SOURCE: Network unlocking
IMEI : 346113011020659 EAN : 6934933000643 help my code
Posted on Feb 07, 2014
HOW TO UNLOCK gALAXY s7 PHONE?
Depends entirely on the type of lock?
A consumer set pass code? Do a factory or hard reset. It scrubs the phone clean and loads a new operating system minus the lock.
A PUK Lock? This is locked at firmware level using a 128 bit RSA Key. Only the telco that owns the phone can unlock it.
If locked to a telco supplier, Bell, Virgin, Telus? Your new telco PROVIDED it is paid off and off contract.
Nov 25, 2017 | Galaxy Cell Phones
Locked out of my galaxy s7 phone cannot remember my pin
I guess Samsung galaxy mobile is locked due to you have entered unlock key more then 5 to 10 times. And now your samsung galaxy mobile is freezed and hard locked.
Now to Unlock samsung galaxy mobile you need unfreeze code and then sim unlock code or sim network unlock pin. You can generate unlock code from imei number of your mobile. it generate 4 codes. First is your sim unlock pin and last is defreeze code.
You can also try this alternate method for unlocking your galaxy mobile.
If you have rooted your mobile and want to unlock it without code then You need custom rom , bootloader unlock file and also flashing tool. And also download samsung driver from samsung site.
Now once mobile is rooted flash rom on it and unlock bootloader for samsung unlocking.
Instead of this you can also try this method to unlock your samsung mobile.
Enter into service mode of samsung mobile by following command *#27663368378# or *#0011#.
then choose debug screen then network lock then select parso sha256 off option. now once your mobile is rebooted it wan't ask unlock code. Howto network unlock samsung galaxy s7 edge
Oct 01, 2017 | Galaxy Cell Phones
Unlock code for Samsung galaxy s7
However easy it is to use. Follow the unlocking Unlock Samsung Galaxy S7 Code Generator steps. You install the Unlock Samsung Galaxy S7 Code Generator. I think it would be at least a bit helpful to know the steps of the SIM unlocking processing. Advance which will be listed here for you:
  • This tool you will find very easy if search on Google.
  • Open the downloaded file and commence the installation procedure.
  • The moment the installation is done. You can see the shortcut of the Unlock Samsung Galaxy S7 Code Generator. It's created on your desktop. You can open it and have a look around the tool. You will see that you will be required to enter your IMEI number. Valid email address of yours for further communication. You are not sure where to find the IMEI. Use the most efficient and fastest way to come to it- dial *#60# from your mobile Samsung Galaxy S7 device.
  • Write down the IMEI.
  • Connect the Samsung Galaxy S7 device you want to unlock to the computer. Before you installed the Unlock Samsung Galaxy S7 Code Generator. You don't have one. You can purchase the USB cable. Then connect cell Samsung Galaxy S7s to computers in any computer shop.
  • After a while your handset will be recognize by its full model and brand. You will see your mobile Samsung Galaxy S7's name in the corner of the open page of the unlocking tool.
  • Click "apply" and wait for a while. With this simple command you actually give an order to the Unlock Samsung Galaxy S7 Code Generator. To use your details and enter the database. Of locked mobile Samsung Galaxy S7 devices. Obtain your unique and original SIM unlock code.
Dec 14, 2016 | Samsung Cell Phones
My samsung phone is locked
Do u forgt ur security code or is ur phone locked to any network
Dec 10, 2011 | Samsung Cell Phones
I HAVE A SAMSUNG GT-S8300 AND IS CURRENTLY BRANDED TO ORANGE. HOW DO I UNBRAND MY PHONE
YOU NEED TO UNLOCK YOUR SAMSUNG GT-S8300.
AFTER UNLOCK YOU CAN USE ANY NETWORK. VISIT HERE THIS SIT AND GET YOUR SAMSUNG
GT-S8300 IMEI UNLOCK CODE.
Jun 17, 2011 | Cell Phones
Unlock sim lock for samsung gt c3303k
MY SIM IS LOCKED .WHAT CAN I DO
May 31, 2011 | Computers & Internet
Unlock code for a samsung gt 1080i
I have the same problem with my phone samsung GT 1080i. it is locked. My IMEI:3547260436219878
Feb 04, 2011 | Samsung Cell Phones
Subsidy unlock code samsung a257 for free
It's very risky to use a free unlock code. It is not 100% safe and could lead to data loss. I would suggest that you visit a SAMSUNG UNLOCK CODE website for your samsung a257 unlock code. They will provide the IMEI unlock code. Just use the IMEI unlock code and your problem is solved.
Jan 23, 2011 | Samsung Cell Phones
Samsung sgh e335
can any give me the sim lock for samsung e335 and phone lock lock # thank you
Mar 07, 2009 | Samsung SGH-E335 Cellular Phone
Cell Phones Logo
100 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
