Question about LG Refrigerators
LG lfc25770st Makes one. round of ice then stops making ice. Any suggestions?
Anonymous
SOURCE:
Anonymous
  • 290 Answers
SOURCE: icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Posted on Oct 25, 2007
Anonymous
  • 75 Answers
SOURCE: kitchenaid superba ice maker stopped working
the oil in the compressor has pumped up to the top hence the ice is not formed the lead valve in the compressor is not working properly so change the lead valve and you could make ice as before
Posted on Jul 25, 2008
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Ice cube sticks and jams arm won't go round
You have a bad mold heater, located on bottom of ice maker.
Posted on May 07, 2009
Joe Hogan
  • 10865 Answers
SOURCE: My ice maker MAKES the ice but doesn't dispense it.
yes. completely warm up the ice maker with a blow dryer until the metal is all dry then spray it with the cooking spray called pam. just regular pam, no other. this will lubricate everything and it will work like a charm. rememer tho it can take up to 24 hours before it will make ice again.
Posted on Aug 16, 2009
Anonymous
  • 11 Answers
SOURCE: Only makes one round of ice !!!! Does not despence.
the overloding or relay is not good , or you have insufficient power supply
Posted on Jan 25, 2010
The arm in the ice maker is stuck in the "up" position
unplug the unit and check if the icemaker timer is working alright. replace with a new one if it is messed up. thanks .
Mar 12, 2015 | LG LFC25770ST (250 cu ft) Bottom Freezer...
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
Lg ice sticks together
hi luke.possibly water over flowing or leaking in.turn water off and try first.hope it helps.Ali
Jun 25, 2012 | LG LFC25770ST (250 cu ft) Bottom Freezer...
Need ice maker parts breakdown AEQ36756907
Hi.
The icemaker AEQ36756907 is sold as a single part. For this reason the manufacturer (LG) does not provide a diagram with the exploded view of the ice-maker assembly (here part). A diagram with the icemaker position in the whole fridge assembly is available in the service manual. Here an example with the same icemaker shown at page 49 in position 600A.
Regards.
Ginko
Other models are similar.
Dec 15, 2011 | LG LFC25770ST (250 cu ft) Bottom Freezer...
Ice maker over makes ice then ice cube tray cannot empty and new water comes in and overflows into ice bin. stop are does not seem to be low enough to cut off production.
WHEN THE UNIT GETS FULL YOU ARE GOING TO HAVE TO SHUT ICE MAKER OFF...
unfortunately there is no sensor to tell the ice maker to stop production so this will happen. sounds like the unit makes more ice that your family uses which normally would be a good thing... just shut the ice maker off until time to make some more and then switch back on ...
hope this helps you out.....
Jan 03, 2011 | LG LRSC26910 Side by Side Refrigerator
LG french door refrigerator ice maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 11, 2010 | LG LFC25770ST (250 cu ft) Bottom Freezer...
My ice machine makes ice but will not give me out cubed ice when its on cubed ice setting 'always gives out crushed ice as my new fridge'freezer is only 1 year old
I found someone who posted with the same problem including a picture: http://www.applianceblog.com/mainforums/lg/18343-help-lg-lsc27910st-crushed-ice-no-solid-cubes.html
I followed his link to the Sears site and it looks like the part number is 6421JB2001D. I don't have my hands on one to confirm it is for sure the right part.
Jul 23, 2010 | LG LSC26905TT Side by Side Refrigerator
Jan 24, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker
check you bail arm .( wire that stops the ice maker) make sure it is hitting the ice when its full. if you can lift it up and it still makes ice then the head is broke and will need to be replaced.
Jun 30, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
101 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
