Question about Refrigerators
KitchenAid model KSF26C6XYY00. Why isn't ice maker making ice?
There is no ice, even where it drops in from the maker
Posted by Dan Coglianese on
umesh bhatt
    Habit-Forming:
    New Friend:
  • 65 Answers
If there is a minor leak of the refrigerant gas then cooling would not be adequate to make ice. Try to set lower cooling in the normal compartment. It might increase the cooling in the fridge section.
Posted on Sep 06, 2020
5 Related Answers
Anonymous
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
korry nguyen
SOURCE: Ice maker stop working
None of the solutions posted here work. I am calling the repairman to fix it.
Posted on May 10, 2007
Anonymous
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
Anonymous
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
Anonymous
  • 63 Answers
SOURCE: kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Posted on Mar 10, 2009
I have a kitchenaid side by side refrigerator model #KSSC42MFS05 and the freezer isn't getting cold enough to freeze ice cream and the ice maker isn't working.
Look at the rear wall of the freezer for a layer of frost building on the outside of that panel. If yes the refrigerator may be missing defrost. That would explain why the feezer temperatures are warming. If the ice maker is above 5 degrees F it will not be able to make ice. Things to check are the=> 2162044 Defrost Timer
The=> 2000631 Defrost Heater
and the=> 4387499 Defrost Thermostat
I would like you to locate the defrost timer and turn the center with a flathead screwdriver slowly clockwise until compressor and fans turn off. Leave like this up to 30 minutes. This will cause the defrost to begin. If timer does not restart the compressor an fans after 30 minutes simply turn the timer again slowly clockwise until the compressor and fans restart. If the timer need to be turned like this then this would indicate that the defrost timer is defective and will need replaced. Let me know if you have questions Thanks Sea Breeze
Sep 25, 2012 | KitchenAid Refrigerators
SAMSUNG MODEL RS2533SW/CUR ICEMAKER MAKING ICE BUT NOT DUMPING
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Ice Maker will not stop making ice
On Your KitchenAid Superba they use an electric eye receiver board part# 4389102. You might want to try cleaning your icebin and the electric eye to see if that works first.http://www.on-timeappliance.com/refrigeratorrepair.html
Mar 27, 2012 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
My kitchenaid superba side by side freezer refrigerator isn't making ice any more. I have been able to get it started by jiggling the prongs that stick up, which is good for a load or two of ice. But...
this sounds like a bad electronic head . you can replace the ice maker to correct problem . its not hard and you may not need the repair man .. mm hope this hepls .. mm
Jul 08, 2011 | KitchenAid Refrigerators
The ICE Maker just Stooped making Ice ? but the water is ok I still get the chilled cold water. There is a Stupid Red Light Blinking I think Twice then stops, Is that a code? this is just 3 years Old in a...
I don't know about the dust bunnies on your coils, sounds like you would have you use a vaccum attacthment or even a compressed air nozzel, but as far as your ice maker goes try totaly turning off the fridge and compleatly 100% defrosting it.
Jul 26, 2009 | KitchenAid Superba KFRS361TSS Stainless...
Ice maker not makeing ice
The most possible 2 reasons for this is the water control valve part number 4389177 or the thermostat inside the ice maker is not working. If ice maker is empty pour tap water until full and lower arm to see if the ice freezes and drops. If this works I would replace the water control valve. Below is a link enter your model number or the part number in the model search feature. There you will see your refrigerator. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
model number KSRS27ILSS02
May 29, 2009 | KitchenAid KSRS27ILSS Side by Side...
Missing Ice Maker metal bar on Kitchenaid model #KSRB25FHSS02
Try pcappliancerepair.com or Repairclinic.com. both are good.
Apr 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Stand Alone ice maker leak
Your model number must be plumbed to a external drain.
You may have to install a condensation pump to do this.
Mar 10, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Kitchen aid ref, ice maker quit making ice
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
