SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
SOURCE: Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
SOURCE: how to remove jet rings on jetted tub
It depends on the brand of jet and tub, if it is a gold or silver trim ring, they will generally pry off with a screwdriver, just be careful not to damage the tub when doing so. When prying, move the screwdriver around the jet an inch at a time, just like opening a can of paint. Some rings will screw on, but most just pry off.
SOURCE: Jacuzi M240 cannot get jets to work
It is most likely the control pad is bad, very gently pry it up going very slowly around the edges with a stiff putty knife or a blade, It will come loose, just be-careful and take your time. When you have it out, look at the bottom where the cable is attaches, if you see anything at all on the circuit board (blue/green oxidation, burns) the board is bad and will set you back 210.00 less shipping. If the board looks good, then it is the control box mounted behind the motor, this box will cost 320.00 less shipping. If you plan on keeping the tub, replace both control pad and box at the same time. Control pad no. M465000 Control box S474000 Both can be found on the internet by their part numbers on google.
hello Tami!
That particular jet is probably clogged.
You can find special cleaners NON ABRASIVE at your local hardware stores.
Be sure to tell them what cleaners you are looking for to make sure it is a non-abrasive type.
Or call in for service. Here is a link that may be helpful to you.
Best of Luck,
JP
Bacteria Alert How To Easily Clean Jacuzzi Bathtub Or Whirlpool Tub Hot...
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: [email protected]
Rod Kidman
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Click on the Link below. Jet Trim have to be matched up by sight.
Find the brand name of your bahtub and click on the name.
http://www.uspartscenter.com/category-s/4954.htm
Rod
US Parts Center
888-521-6183
