Question about Refrigerators
G10010 not cooling properly - Refrigerators
Posted by Trent D Johnson on
Kardoc
    Top Expert:
  • Refrigerators Master
  • 6,126 Answers
Https://www.familyhandyman.com/project/fix-refrigerator-problems/
Watch this video for some hints on what to do.
Posted on Sep 05, 2020
I have dometic AC 630515.331. I was having a problem with it cooling properly. A service guy checked it out and said the cold control wasnt working properly. Im trying to replace it but I dont see a cold...
When you say, wasn't cooling properly, could you give more details such as, cooling would not shut off, cooling would cut out before trailer was cool, fins/coils were frosting or freezing up. Compressor was kicking out and in too much or any other symptom you notice. All will help with proper diagnosis.
Apr 02, 2013 | Dometic Rooftop RV Air Conditioner
Freezer not working
Check the help links shown below :----Refrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html-----------Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This willhelp.
Thanks.
Feb 10, 2012 | Maytag MBR2256KES / MBL2256KES
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
It won't get colder than 54 degrees. Why won't it get cold?
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Apr 25, 2011 | Haier HRT02WNCBB (17 cu ft) Compact...
Compressor keeps running but no cooling?
Check this video, might give you better idea what could be wrong with that compressor. We cut this one open, found couple issues.
Feb 10, 2010 | Traulsen G10010 Refrigerator
Traulsen reefer iced up,
electric heater must activate and warm to de-ice the evap coil in the correct amount of time ..elements setting under evap coils.ck for voltage to element leads while in defrost.You may wish to remove X terminal wire from defrost clock in order for the clock not to terminate early
Jun 17, 2009 | Traulsen G10010 Refrigerator
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Traulsen 30" two door frodge 7 years old (just moved today)
Compressors don't like to be laid down, the rotor swims in lube that is disturbed when horizontal.
If the compressor isn't ruined, the noise could emanate from the fan that most units have, sometimes two; one to circulate air around the fins, another to stir air inside.
Pull the plug on the fridge while it is running and try to listen to the character of the noise before it stops.
If it is very rapid; I suspect the compressor is history.
If it makes kind of a singing noise while coming to a stop, it could be fan blades hitting something.
Jul 16, 2008 | Traulsen G10010 Refrigerator
Traulsen g10010 troubleshooting
full service call video. Traulsen Refrigerator. Found bad motor and replaced. I hope it will help.
Jun 15, 2008 | Traulsen G10010 Refrigerator
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
