Question about Refrigerators
I was given a used kitchen selectives 8 minute wine chiller but the charging cord is missing It calls for a 9v adapter cord Can I purchase this anywhere?
Posted by Connie Swentek on
Andrew Taylor
    Top Expert:
  • Refrigerators Master
  • 31,554 Answers
Can anyone direct me to an operating manual for the Brandt Wine Chiller?
Search Results
    Download brandt wine chiller manual - Google Docs
    https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesLooking for brandt wine chiller manual? Download brandt wine chiller manual.brandt wine chiller manual. User Manuals, Instructions and Guides.We have that ...
    brandt manual Refrigerators Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > brandt manual
    On my Brandt wine cooler at the top is an adjustment control for temperature. ... is amanual for this refrigerator LG top mount ice box service manual Maytag ...
    Free Refrigerator User Manuals ' ManualsOnline.com
Dec 14, 2015 | Refrigerators
Food network electric wine opener will not open
Take a look at this review and see if you are missing something in its use. Basically, put in charger base, connect transformer to the mains and charge for 8 hours. Remove the foil from the bottle top, put the wine opener on top of the bottle and press the button.
Oster Electric Wine Opener Review
Feb 23, 2014 | Sunbeam Oster Electric Wine Bottle Opener
Kitchen selectives rechargeable wine chiller bc-10r 8 minute chill
For the KITCHEN SELECTIVES WINE CHILLER...A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, plug in and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps! 8d55b92a-9870-497d-a9c6-7cda8d40c58a.jpg 11a83201-002b-4f0c-b811-810f4cf0046e.jpg
Dec 16, 2011 | Refrigerators
I have a kitchen selective mod. #BC 10R I dont have the operational manual for this and cant seem to get it to work. I dont know if it is broken or if there is an operator error. Please help me out. We use...
Hello, couple things first. This is posted under a cm-202 coffee maker yet the BC-10r is a wine chiller. Yiou are looking for the instructions for the wine chiller correct? Also I am a service repair person that repairs refrigerators and coolers as well so if you can describe what the unit is doing when you turn the unit on or plug it in as well as if you can see any led lights lit on the unit as well I would be able to tell you what is also wrong with you unit also.Please provide full model numbers and any serial numbers as well on your unit. I await your reply
Thank you
Rick
Nov 24, 2011 | Kitchen Selectives CM-202 Coffee Maker
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
Need Owners Manual for Kitchen Selectives Wine Chiller (1 Bottle)
A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, turn on and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
Jan 16, 2009 | Kitchen Selectives CM-202 Coffee Maker
Durabrand Portable DVD w/dual Screen
http://www.unitedsale.com/product_info.php?products_id=17976 This link is for an Audiovox DVD player, but it may fit yours or else you can cut off the plug on your existing power adapter and reconnect it to this one. Also try searching Google for "AC adapter 9V 3A".
Apr 17, 2007 | Durabrand Portable DVD
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
