Question about Necchi Sewing Machines
How do you tighten tension on bobbin on a necchi 4595?
Posted by Dawn on
3 Related Answers
ken dourof
  • 980 Answers
SOURCE: bobbin tension is too loose
On the bobbin case there are two screws, make sure the bobbin turns anti clockwise inb the bobbin case as you look at it, turn the larger screw clockwise to tighten the tension about a quarter of a turn and test, keep adjusting until you get it right
Posted on Jun 27, 2010
SOURCE: My Necchi 4595 has never really worked
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Nov 17, 2010
Debbie
  • 1860 Answers
SOURCE: necchi 4595 manual
try these links for a manual
Instruction Manual Necchi 4595
Necchi 4595 Instruction Manual
Posted on May 05, 2016
I have a Necchi sewing machine The bobbin thread is way loose. What should I do
Start out with a brand new needle.
Be sure the machine is threaded properly. Also, the presser foot MUST be raised before threading so the thread will seat properly in the tension disk.
The standard setting for the upper tension is the midway point between the high and low number.
If the bobbin thread is still way too loose, you can try adjusting (tightening) the bobbin case tension. If that does not fix the problem, you can probably try purchasing a new bobbin case for your machine as the old one may be broken or worn.
adjust bobbin tension Google Search
Jan 27, 2016 | Necchi Sewing Machines
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Jan 30, 2015 | Necchi 6030 Mechanical Sewing Machine
Bottom thread will not be pickup
There is loose thread hanging from the lower bobbin, isn't there?
Dec 12, 2013 | Necchi 4595 Mechanical Sewing Machine
Necchi 4595 feed dogs keep dropping
Tighten the screw under the plate near the feed dog
Sep 20, 2013 | Necchi 4595 Mechanical Sewing Machine
How do u thread and set tension on necchi 3205
sewusa.com has some threading diagrams
& you can also see if sewingpartsonline.com or premiersewing.com
have manual for the sewing machine
Mar 15, 2012 | Necchi 4595 Mechanical Sewing Machine
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
thread breaks
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Stitches looping up on bobbin side of fabric
you may have to adjust the tension of the Bobbin. There usually is a screw to adjust this on the bobbin housing(the part that holds the bobbin). Try tightening the tension by turning this screw clockwise a little bit. It may work for you. Also clean any debris from the bobbin compartment which may cause this problem also. Hope this helps..WF
Aug 21, 2010 | Necchi Sewing Machines
Bobbin tension is too loose
Jun 23, 2010 | Necchi 3537 Mechanical Sewing Machine
I need a manual for a Necchi Royal Series, #4795FA. Threading Diagram and Instructions to set the correct tensions on the Thread and foot
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Mar 14, 2010 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
Top Necchi Sewing Machines Experts
tina gallow
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
