Question about Toshiba Televison & Video
HI I recently bought a TV Toshiba 49 inch model 49V5863DBT. The TV has got a solid colourful lines running in the middle. They on every channel on all sources. Lines are in front of everything.
Posted by Krzysztof Rutkowski on
John Wood
    New Friend:
  • 73 Answers
You have a faulty screen.. usually the cost to replace is more than what it is worth.
Posted on Feb 14, 2020
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Posted on Jan 05, 2008
Anonymous
  • 4 Answers
SOURCE: JVC 65 inch projection tv
thats how my stared than got worse i call for service and got fix after 4 moths had the same problem and i called the same guy again at firs he told me that the convergence was bad and replaced them i think there are three pieces but than the second time he took the box inside the tv he checked all the circuits and the board and he found out the something else was getting real hot and was causing that the convergence to bad now he fixed hope i got no more problems
Posted on Feb 16, 2008
Anonymous
SOURCE: White lines accross top of screen on our 27 inch Toshiba,
My Toshiba required replacement of two of the vertical filters/capacitors. Doesn't take long and the parts are inexpensive, but requires a repairman.
Posted on Sep 12, 2008
Anonymous
SOURCE: Toshiba 50HDX82 screen flickers at the top
Replace the Hyper Board, There 11 10uf 16v cap's that go bad.
Common Problem with this set
Posted on Feb 16, 2009
Anonymous
  • 473 Answers
SOURCE: my toshiba 32 inch lcd tv has green ,red,and
Change Your Regulator on your Color Mixer check the choke beside it the little yellow trasfomator beside.... It maybe damage too....
Posted on Sep 21, 2010
Recently bought a Dynex flatscreen 32 inch tv and noticed faint lines moving up the screen. Some channels it is really noticable and others not so much. Tried switching out the coax cable cord and that...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Take care in solving the problem..
Sep 12, 2011 | Dynex Televison & Video
I have bpl tv model FYR 21 NEPTUNE and there is a problem in its colours uniformity. due to les green colours of pictures reflects the purple colour. please tell me the solution for setting its colours
my tvs volume has been increasing suddenly on serving the channels mostly above 20th channel recently the picture disappeared it shows red line in the middle but volume is present quickly give me the solution
Sep 29, 2010 | Televison & Video
Old toshiba
Hi Veronica,
I need to know exact model number of your Toshiba TV to help you out.
You can find it at back of TV on some kind of sticker.
Oct 11, 2008 | Zenith R49W36 49" Rear Projection HDTV
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Philips dvdr3480 picture problem
swap the scart inputs around. See if that solves it
Sep 02, 2007 | Toshiba DVD Recorder
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Setting the channels
You can download the manual from the link below: http://safemanuals.com/download_94794.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
