Question about NorStar Lands Phones
Programming internal extensions' names - Meridian Norstar M7310.
Posted by Danielle Jarabak on
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Adjusting the contrast on the Norstar Meridian M7310
You don't need no steenkin' manual :-)
FEAT *7 and the UP DOWN arrows work well.
If you must.... http://public.carl.airpost.net/M7310_ug.pdf
Now you do.
Carl
Posted on Jan 20, 2009
Vit Avaya BP
Vitaly Kagan
  • 211 Answers
SOURCE: What is a Norstar Overlay Template?
right top Show
right bottom Next
left top Heading
left bottom Back
Posted on Mar 23, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: how can i change my extension nuber (norstar M7310)
Sorry can you clairify this question...
-> You need a new extension number for your set?
-> You need a new extension on your set so you can see when they are on their phone?
If it is the first, there are many things that you need first, too much to explain at the moment. But you need to have the password and a template for your phone to make changes.
If it is the second, press:
- Feature * 0 and any button to find out what is on the button, look for an empty button or one that you want to overwrite,
- then RLS,
- press FEATURE * 2
- press the button where you want to add this new extension
- dial the extension of the new person
Voila you are done!
Posted on Jun 03, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: Meridian Norstar M7310 -- Phone's buttons seem disabled.
Sounds like a stuck button!
Look for the button that is depressed... or the button that has that person that the set is always calling and remove that button with a key/ small knife/ screwdriver or something.
When you take this button off the set, I bet that your set will start working again.
Clean that button, maybe there is something spilled on it.
Good Luck.
Posted on Aug 29, 2009
consultel1
george peters
  • 860 Answers
SOURCE: Change extension to another line pool
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the show key (top right arrow)
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key till you get to the desired pool(bottom right arrow) .
Press the Chng soft key from N to Y
Press the heading key till the display says Line Pool Access(top left arrow).
The display should say Prime Line
Press the Chng soft key till you get to the desired pool
Press the release key when finished
Posted on Oct 01, 2009
How to program feature buttons on meridian 7310?
Go to 7310 set you wish yo program leave handset on hook push feature star 3 then the button you wish to program then feature and
the code you want ex:feature 0 is speed dial that key will now be
programmed for speed dial. You cant program line keys or intercom keys.
Sep 02, 2014 | NorStar Meridian M7310 Phone
Why doesn't one phone in my norstar meridian m7310 phones is not displaying caller id
Either COPY the config settings from a set where it works to those that don't, or on the sets that do not:
F**CONFIG, Terminals&Sets, (enter ext #), ... Telco Features, 1st Display Name: change between Name, Number, or Line.
And remember that some callers (esp Cellphones) do not provide Name info, so if the incoming calls at that extension are mostly from the same #s, it might be normal.
Aug 11, 2014 | NorStar Meridian M7310 Phone
How to change the extensions connected to the greeting? M7310
This is most likely done in the CCR programming. Someone that is knowledgeable in making changes to the trees needs to make these changes.
Dec 19, 2012 | NorStar Meridian M7310 Phone
Nortel Norstar T7316 programming extention to button. Won't let me program extension 230.
Just think about it, why would you want to auto dial yourself? You don't need an autodial key for yourself so the system don't allow you to program it.
Sep 25, 2017 | NorStar Meridian M7310 Phone
How can I change a name on a display screen for the telephone model M7310?
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
Enter extension number you want to change the name on.
The display should say LINE ACCESS
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Aug 20, 2010 | NorStar Meridian M7310 Phone
Good Luck.
Jun 21, 2009 | NorStar Meridian M7310 Phone
right top Show
right bottom Next
left top Heading
left bottom Back
Mar 23, 2009 | NorStar Meridian M7310 Phone
Merian M7324 display name
you would need to get into the admin programming to change the name, have your system admin person make the change for you.
Jan 02, 2009 | NorStar Meridian M7310 Phone
M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
Nov 05, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
