Question about Pride Health & Beauty
I have a pride celebrity scooter, it has a beep code which is not in the manual
Posted by Victor Keller on
Raan Lon
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
<a rel='nofollow' href="https://greatbritishmobility.co.uk/discount-mobility-scooters">discount mobility scooters</a>
Posted on Feb 11, 2020
5 Related Answers
Dan Hudson
  • 118 Answers
SOURCE: instruction manual for celebrity pride 3 wheel mobility scooter
I can send you the manual (PDF) if you send me your email address. My address is (D*H*u*d*s*o*n at GMail dot com), you need to take the stars out and put the @ symbol in and the .com to make it usable.
Posted on Jan 07, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
my-mobility
my-mobility
  • 9 Answers
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… [email protected]
Posted on Jun 22, 2009
beezaville
  • 8 Answers
SOURCE: Pride celebrity XL won't go.
Have you checked the motor brushes for wear and spring tension, sometimes the spring becomes brittle and breaks but can sometimes still make contact.
Regards Steve.
Posted on Jan 10, 2010
Neil Wood
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
HUSBAND FLIPPED HIS PRIDE CELEBRITY X SCOOTER STOOD IT STRAIT UP IN THE AIR.NOW NOT WORKING.5 FLASHES
Five beeps? Maybe it's not the same as my Celebrity XL8 but my instruction manual talks of a 1+4 beep warning meaning low battery charge. It also suggests checking that the wiring harness connectors are all fully connected - that would include the battery terminals of course. If your hubby managed to do a wheelie this sounds a strong possibility if the batteries were dislodged. Anyway, I attach the page from my Celebrity XL8 manual, you can find other Celebrity manuals online. My congratulations to your husband, I've yet to master wheelies!
Jun 13, 2017 | Pride Health & Beauty
Can anyone help me? I own a pride celebrity lx8 scooter. It is beeping 3 and 1 or 3 and 2. What could this mean please? Many thanks R
Yes I done a quick search on the beeps it took me to the same fault codes as the book TRY SENDING AN EMAIL TO www.pridemobility.com.au....good luck..Hi again yes I just picked up the fault book and they call them flash codes I WILL CHECK INTO THE PROBLEM cheers. Hi 3 flash code unplug charger turn key of then back on again , 1 flash code charge batteries 2 code same as 1 charge batteries good luck
Jul 06, 2016 | Pride Health & Beauty
Pride celebrity scooter brakes
Faulty brake or scooter in freewheel.
Aug 25, 2014 | Pride Celebrity Xl 4 Wheel Scooter
What do pride celebrity x sport error codes mean
Download the otherwise fairly useless Pride owner's manual, the beeper codes are listed there.
Jun 12, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Celebrity x mobility scooter . error code 5
The freewheel lever is in the neutral position (which allows you to move the scooter around by pushing it. Turn the key switch off then move the lever to the drive position , turn it back on and it should run fine. The freewheel lever is sticking up through the plastic cowl. It is located under the seat on the right hand side near the rear of the sccooter
May 27, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Error code 5 pride celebrity x
The manual freewheel lever is in the (forward) freewheel position.
Remove the key from the key switch, then push the manual freewheel lever to the drive (rearward) position and restart your scooter. The manual is at...
http://r.duckduckgo.com/l/?kh=-1&uddg=http%3A%2F%2Fwww.pridemobility.com%2Fpdf%2Fowners_manuals%2FUS_Scooter%2FUS_Celebrity_X_om.pdf
May 27, 2014 | Amigo RD 3-Wheel Scooter w/33AH Batteries...
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
Celebrity pride xl fault codes
Look on ebay for manual or here:
http://www.pridemobility.com/pdf/owners_manuals/intl_scooter/uk/uk_celebrity_xl8_om.pdf
Apr 04, 2013 | Pride Celebrity Xl 4 Wheel Scooter
Health & Beauty Logo
87 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
