Question about Dell OptiPlex GX260 PC Desktop
I have a problem with my network card driver - Dell OptiPlex GX260 PC Desktop
Posted by eh_center on
  • Art Ellison
    Art Ellison May 11, 2010
    And what would that problem be?
  • Melissa Haskell May 11, 2010
    Do you get an error? I need more details?
    Find out if you need a driver and download that.
    Find out if your pc needs any updates?
Anonymous
  • 32 Answers
Kindly update your networkcard driver
Posted on Sep 19, 2009
Bill Schilz
    President:
  • 2,049 Answers
Here is a link to the Dell drivers for your GX260. Scroll down to Network and select what you need. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_P4_GX260&os=WW1&osl=en&catid=&impid=
You may need to go in and delete the network card first and the reinstall it.
My laptop network card dissapeared, i have no network hardware. How do I fix this problem
go to device manager and find the network card check whether the driver is installed or not, if the driver is installed properly then use genius driver professional or cobra driver pack to get the updated drivers
Apr 07, 2010 | Dell Ethernet Card Network Adapter
Ethernet light at the back of the computer does not light up, also does not recognise cable.
Check the dell website for support and drivers for your computer. go to www.dell.com and put your service tag into the proper section.
You either have the wrong driver for your network card or the network card is not functioning. You need to be sure the card is seated properly in the card slot first.
Chedk the device manager to see if the network card is recongnized. Go to your My Computer icon, right click and go to properties and then the hardware tab.
Look under network cards and see if you card is visible and if the driver is loaded for this card. If the card is there, try to download an updated driver for your network card.
I hope that you find this information helpful, if so, please leave feedback for me.
Thank You,
Brian .
Jan 25, 2010 | Dell Ethernet Card Network Adapter
Replaced hard drive on HP dv4000. Install XP Pro and drivers from recovery disk. Updated to SP3. Do not have 1394 net adapter listed in network connections. Connected external hard drive to firewire port...
I would check in device manager (control panel) and see if the network card is listed. It probably has a yellow exclamation point next to it. If there is an exclamation point there, then right click the card and click uninstall. Next, using your wifi to access the internet, download the latest network card driver from the PC vendor website / Motherboard vendor site / discrete network card site.
Install the network card driver and you should be back in business.
Jul 09, 2009 | HP A6795A#0D1 Network Adapter
I NEED LAN CARD DRIVER FOR D600 LAPTOP
If you want the driver for your Dell laptop, the best place to get it is at support.dell.com.You need to input the model you have, ( which I believe to be a Latitude D600), and choose drivers.
On the driver page, choose your computer's language, network for category and all for importance.
This brings up about 20+ possible downloads.
You then need to find the ones that apply to the network card in your computer that are labeled as drivers.
Anything labeled as firmware is optional and will upgrade the operation of your card if applied. Utilities are also optional and are usually used to change operational settings of the card.
There will be only one driver for your card that you have to download, everything else is optional.
Once you have the driver, look at the device manager in WinXP.
If the network card [ethernet adapter] is not showing there, then there should be an unknown device.
Right click on the unknown device and choose update drivers and point the update wizard to the driver you downloaded.
That should solve the problem.
Feb 18, 2009 | Dell Ethernet Card Network Adapter
Windows XP Boot CD Network Boot Drivers
I would try to boot in safe mode, then download the appropriate card driver.
Jan 23, 2009 | Microsoft Windows XP Professional SP2
Asound Ethernet card drivers for win2000
Try this driver:
http://www.network-drivers.com/drivers/57/57700.htm
Jan 19, 2009 | Asound 22332 Network Adapter
Network card
A lot of network adaptors can work using generic drivers. Myself, I download drivers from manufacturer's websites such as acer (the maker of my laptop) and found that the drivers they provide can be used on a lot of different systems. I found a website that provides a list of network adapter drivers.. have a look on this site. I would suggest the realtek driver, but if you can find out the model or manufacturer of your card, it would be a lot easier
Jul 06, 2008 | Computers & Internet
Ati display card with network card built in
http://ati.amd.com/support/driver.html here you can download ATI drivers for your OS and Card, it's as easy as that.
May 21, 2008 | ATI RADEON 7000 PCI Graphic Card
Dell OptiPlex GX260 PC Desktop Logo
116 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
