SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
SOURCE: need bernina sewing machine model 730 manual
Here is a download - http://www.berninausa.com/webautor-data/486/BERNINA_730_731_732_manual.pdf
SOURCE: Looking for manual for White sewing machine model # 311
try www.sewing-machine-manuals.com and click on relics.
SOURCE: Looking for sewing machine manual for singer
I went to the singer website & typed the number in 6218 & it came up with nothing, is that the correct model number?
the tension problem try adjusting the top thread tension to 3-5, & see if that helps the loose tension
SOURCE: problem with taylor professional sewing machine mo...
http://www.singerco.com/uploads/download/1290_834.pdf
