Question about Hardware & Accessories
I just installed a new motion and auto on at dusk off at dawn light fixture under my porch by my front door. Problem is the fixture hums with switch on, even if I remove the lightbulb. Wires correctly. What is wrong?
Posted by Jodi Stevens on
4 Related Answers
Anonymous
  • 3 Answers
SOURCE: Dual Brite sensor lighting. Lights will not stay
I really don't understand why these lights are so failure prone and I usually return at least 8 out of 10 back to the store but I've installed a lot of them. If its Zenith brand the light may need to be reset by turning the power off at the switch or breaker for 1-2 min then back on. Then check the motion sensitivity dial if its maxed out turn it back and set it to 75% full also the photo eye may be getting light from the light making it think its daytime at night so try to reaim the photo eye if possible away from the light source that should fix most problems or 20% of them but if you still have problems return it to the store or ask for their advise. Hope this helps I've seen a lot of junk motion lights in my time they are troublesome at times.
Posted on Jul 17, 2009
Anonymous
  • 53 Answers
SOURCE: I have an outside spot light with a motion
First, let me say that if you're not entirely comfortable doing high voltage electrical work, you might want to call an electrician. It's not impossible for you to get hurt or killed or burn down your house. At least be sure to turn of the circuit breaker while you're working on it.
The blacks and whites twisted together are passing through power to other parts of your premises and are always on, so be sure to keep them twisted together. The red is the one that will take power from your light switch and send it to your light fixture.
At the fixture, connect the white to white and red to black, the same as before. At the light switch, connect the black to one side of the switch and the red to the other. When you turn on the switch, it will permit power from the black to travel down the red to the fixture, and from the fixture, the circuit will be completed through the white.
Posted on Sep 12, 2009
Anonymous
  • 27 Answers
SOURCE: Need wiring diagram for installing a photoelectric
I am reasonably sure the black wire connects to the black/hot power wire coming in, and the red continues on to the light. I am positive the white wire is connected to all the other white wires. The white wires usually do not connect anywhere on the device, just wire nutted together in the box
Posted on Nov 03, 2009
hardwater_39
  • 7 Answers
SOURCE: I installed a dusk-till-dawn switch on a light.
Make sure the sensor's eye is pointing North
Posted on Dec 07, 2009
Installed light fixture & Now No Light
It would be helpful to know which timer you have. But from what you mention, there is another switch involved. Was this on a three-way circuit? That is, was this light controlled by two separate switches? In that case, you need to know which wire goes to the live and which to the light. Not easy without a tester.
Other than that, send us the switch make and model number and we can look at the wiring diagram. Cheers.
Jun 29, 2015 | Hardware & Accessories
Photo cell goes on too eary and off too late. any suggestions?
If photoeye is under covered porch, it will do what you describe
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
http://waterheatertimer.org/How-to-troubleshoot-timers.html#photocell
Otherwise, point the photoeye toward the east
You can disconnect photoeye
Then replace single-pole or 3-way light switch with dawn-dusk astronomic timer ... which lets you set 10-15 minute delay from the internal astronomic clock
http://waterheatertimer.org/Programmable.html#st01
http://waterheatertimer.org/ST01C-program.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 05, 2014 | Hardware & Accessories
I have a 6yr old porch light that has two buttons. how do I reset it so light will come on?
Sorry bro not familiar with the track lights. I thought you were running regular lights.... I was curious if they have a powered track or curled wire.... if it is the powered track which I doubt a friend of mine had manufacturer gunk on his indoor one that was fixed with a little emery cloth.
Sep 09, 2014 | Heath Zenith SL-4305-WK Motion-Activated...
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
Gene
h
Aug 18, 2013 | Electrical Supplies
We have a motion sensored light with two lights and the motion box. 1 black wire and one white per light but the middle has 1 black, 1 white and 1 red. We are hooking it to the porch light and dont know...
You are replacing porch light with light fixture with motion sensor device.
Each light has 1 black and 1 white wire.
The motion sensor has 1 black 1 red 1 white:
Copy following link for motions sensor wiring illustration:
http://waterheatertimer.org/How-to-wire-switches.html#motion
Oct 17, 2012 | Hardware & Accessories
Why does dusk to dawn light have only a dim light
Add a comment to start dialog.
Probably the photosensor is wired wrong? Or is bad.
Which light fixture do you have?
Is the photosensor integral to the light fixture?
What wiring did you change?
What was the matter with the previous wiring?
What else is on same circuit?
Aug 28, 2012 | Hardware & Accessories
I bought two motion sensing diecast lanterns model HB-4190 series, SKU 248-593 and the instructions are hard to understand. To make it easy tell me how to set the device if I want it to come on only if...
Hello Gerald. Each switch has a function. the the test-1-5-10 allows you to set it to test or an on period of 1 or 5 or 10 minutes. The off-3-6-dusk to dawn allows you to turn it off completely, operate from dusk for 3 hours, operate from dusk for 6 hours or operate from dusk to dawn. By operate I mean turn on and then stay on for the number of minutes you set it to with the other switch.
what's nice about the test setting is that with it allows you to check and b sure that the light will come on during daylight by setting the one switch to test and the otner to any setting but off.
If you leave the 2nd switch set to off the first switch will not allow you to test it.
Joe
May 22, 2011 | Garden
Dual Brite sensor lighting. Lights will not stay on even after human motion is in place sight of sensor during evening hours. I have the switches on dusk to dawn and the on-time switch is set to 20...
Jul 12, 2009 | Electronics - Others
Hardware & Accessories Logo
90 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
