Question about Honeywell Air Purifiers
You didn't indicate the model. Perhaps this support page from Honeywell can help.
https://www.honeywellpluggedin.com/air-purifiers/support
Posted on Apr 13, 2020
SOURCE: how to find the carbon filter to change it and how we should clean the hepa filter on our
You should contact Honeywell to find out their parts rep for your area. I don't think you will find these parts in the regular hardware store.
Use Google to find the Honeywell home page, and work from there.
Jerry G.
Posted on Apr 27, 2008
SOURCE: Panasonic F-P10HU1 Air Purifier
I found one on Google - the part number for this is the F-Y15XS. A number of small online stores have it. Good luck!
Posted on Sep 22, 2008
SOURCE: I have an older honeywell hepa filter and it has a
when the filter is full, pressing the button resets the cutout. either shake out the filter or replace with a new one.
Posted on Oct 17, 2009
SOURCE: my honeywell air purifier is emmiting an awful
Mine quit too... The led screen went blank so I changed the battery. Now it does nothing. I totally disassembled it as the fan was turning stiffly.(should spin very easilly) The grease in the end bearing was stiff. I washed the gummy grease off the shaft and reoiled with synthetic oil. Your smell is probably motor windings overheating. I disassembled the electronic control and was disgusted to see that there is a glass fuse soldered to the circuit board. I believe the only reason for this fuse is to cause us consumers to needlessly replace otherwise good equipment. (It cost more to pay a repairman to replace the hidden fuse than to purchase a new unit)The fuse is not blown. At least this fuse actually looks lide a fuse unlife the stealth fuses most electronics have hidden in them. I can not obtain a wireing diagram on my 17005 unit but it has a black box inside behind the control panel. It looks like a small start capacitor, but it has a temp rating on it of 70*C. I suspicion it is a single use over heat safety which triggered when my motor got hot due to stiff bearings. I refuse to play their game and purchase a new air cleaner. I love this one... So, if I can not determine what that little black box is, I am going to bypass all the crappy electronics and just drill a hole on top by the handle and install a hi/lo/off manual switch directly to the motors wire hasness. This machine will never give me problems ever again, and if I oil the motor every couple of years with synthetic (Ander oil) this unit WILL last me for the rest of my life...
Posted on Jan 02, 2010
SOURCE: Why HEPA certified Filters are more preferred?
you can refer to this source for best answer
http://buypuritii.com/
Posted on Dec 09, 2016
