Question about Refrigerators
Ice maker leak / freezing up. Any shortcut to remove the ice? RF24FSEDBSR has ice maker in fridge so ideally I want to turn off only the ice maker without turning off Fridge or Freezer
Posted by John Billington on
Tom Chichester
    Top Expert:
  • Refrigerators Master
  • 61,810 Answers
The old reliable hair dryer
Posted on Nov 08, 2020
5 Related Answers
Anonymous
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
Anonymous
  • 9 Answers
SOURCE: Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
Posted on May 01, 2009
Anonymous
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Sep 06, 2009
The icebucket is frozen and I can't remove from my fridge
a hair dryer and wet hot towels (microwave) works wonders in this case , most times I see this happen I find the ice maker water valve bad (very bottom left corner)
1helpful
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
3answers
I have a Samsung bottom freezer top fridge RB215LASH. Water leaks from the inside back panel down under the crisper. The drain is not clogged. Their is no problem with the evaporator coils freezing...
OK, first there is only two ways water can be entering the fridge under any circumstances, one is through the Ice Maker feed line coming from your wall to the back of the fridge and into the ice maker. The other is from the ice trays themselves leaking or overflowing or the filter itself is leaking. Look at the side walls of your refrigerator, are there water streaks running down the side? Have you reset the ice maker since you did your repairs? Have you replaced the filter lately?
Usual Causes
If the water pressure is too high, the ice tray can over fill or water can splash out. You can turn the supply shutoff valve to reduce the water flow. See the diagram below. If the ice cube tray has residual pieces of ice in the bottom, remove the pieces by pressing the reset button. You may have to do this several times to clear all the ice out of the tray.
Get back to me and I know you provided a lot of information, but this is a inline water issue relating to the ice maker and not really thinking it could be anything else. So if you can give me more information about the form in which this happens, such as you find the water after the trays are filled or if this is a constant but minimal flow, large flow, we can concentrate our plan towards this are of the repairs and diagnosis. Look forward to hearing from you soon.
My frigidaire side by side freezer freezes up and the filter in the refrigerator leaks water. It makes ice fine but will not freeze ice cream. theres a big clump of ice in the back which is under a cover...
the leaking water is the problem. it needs to be fixed, but till then defrost again, use a fan it speeds the process, SHUT OF WTER to ice maker. restart fridge it will work normally. now find parts needed to fix the ice maker water feed.
the leaking water overwhelms the defroster. and causes a coil freeze up, this impedes cooling and air circulation over the evaporator coils
1helpful
2answers
Ice maker makes ice then water dripps and freezes
water valve not working properly needs to be replaced ... located on bottom back nof fridg
2answers
Water leak
IF THE ICE MAKER AND DISPENSER ARE BOTH OFF, THE WATER VALVE IS THE PROBLEM. THERE SHOULD ONLY BE WATER RUNNING WHEN THE ICE MAKER CALLS FOR IT, AND THAT SHOULD ONLY BE ABOUT 7 SECONDS WORTH,
(4 OUNCES).
THE ONLY THING THAT PUZZLES ME ABOUT YOUR DESCRIPTION IS THAT YOU SAY ICE FREEZES OVER THE COMPRESSOR. THE COMPRESSOR IS THE HOT ROUND OBJECT LOCATED UNDER THE REFRIGERATOR OUTSIDE THE COOLING COMPARTMNTS. FREEZING ONLY TAKES PLACE IN THE FREEZER COMPARTMENT. ARE YOU TALKING ABOUT THE EVAPORATOR COILS? IF THERE IS WATER THERE, THE ICE MAKER COULD BE STUCK IN THE FILL MODE AND THE BACK OF THE ICE MAKER FROZEN SO THE WATER CAN'T REACH THE MOLD OF THE ICE MAKER.
CHECK THE FRONT OF THE ICE MAKER BEHIND THE COVER FOR A BROKEN GEAR. IF IT HAS WRITING ON IT THAT SAYS DO NOT ROTATE MANUALLY, YOU NEED TO REPLACE THE ENTIRE MODULE ON THE FRONT OF THE ICE MAKER.
2helpful
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
