Question about Refrigerators
I have a hisense HR6TFF526 how do I remove the white plastic handle from the clear base of the big base drawer of the fridge so I can clean it?
Andrew Taylor
    Top Expert:
  • Refrigerators Master
  • 31,538 Answers
Unlikely that you can as it is probably snapped into place. Swab it with neat Hydrogen Peroxide. Leave 10 minutes and rinse off.
Posted on Feb 02, 2020
5 Related Answers
SOURCE: Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Posted on Jul 07, 2007
Anonymous
SOURCE: door removal
on my trio the handles slid up with a bit of force and then pulled off to reveal screws.
Posted on Oct 27, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: GE Spacemaker 1800 Handle Base Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 06, 2007
paul campbell
  • 1071 Answers
SOURCE: The drivers door handle on my 2000 Hyundai atos
no just a flat blade screw driver the clip should pop off it may have a **** shell type which you pop **** shell open and pop off rod
Posted on Aug 18, 2009
Anonymous
SOURCE: Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
Posted on Dec 13, 2009
I'm trying to clean the top of the pantry drawer in my 795-72053 refrigerator. Liquid has seeped between the clear plastic and the white. How can I remove this piece to clean it?
You have two drawers side by side that are called the crisper bins and one long drawer at the bottom typically called the deli drawer. I think what you are asking is how to separate the front (clear part) of the drawer from the back (white part) ,right?
Usually there are snap tabs that need to be pushed in to release the two pieces but I need to say that they are very fragile and break quite easily so be careful!
I would try soaking the drawer to get whatever it is cleared from it and let it dry completely. Keep in mind that there is usually a left and right specific drawer so if it doesn't fit then do not force it!
Jan 28, 2018 | Refrigerators
Hi there, have a Hisense fridge model hr6tff526(s) which is leaking water from the inside,looks like its coming from the top where the fan is located.thx
Hi Kassem
It's probably just condensation water like what you get under an air conditioned car in the summer.
Usually in a Fridge they collect the condensed water and run it down a clear hose pipe to a plastic container at the bottom rear of a fridge.
This pipe can become blocked with food & junk & mould, mice etc.
Find one end and clear the obstruction. A flexible rod or wire or air burst.
Cheers
Example Repairs:
DIY troubleshooting and repair for RV refrigerator condensation drain tube...
How To Clean Air Conditioner Drain Water in Drain Pan
Fridge Leaking Inside Refrigerator Drips From Ceiling Defrost Clogged...
Sep 14, 2016 | Refrigerators
How do you remove the clear plastic cover on the crisper drawer of a Samsung Refrigerator Model RF4287HARS
Yes, the clear plastic front of the crisper drawer can be removed for cleaning. Using a thin-bladed, flat-head screwdriver, pry out at the clear plastic slot at the top outside of the drawer, where the clear front piece meets the tab of the white handle piece. Pry out just enough to get the blade under the slot, and then pry inward at the white tab to release the clear front piece at the top of the drawer. Repeat this procedure on the opposite side, so that the plastic front piece is free at the top of the drawer. Next, turn the drawer over on a counter and work the blade of th screwdriver under the tabs at the bottom of the front plastic piece. These should release easily. Notice the bottom edge has three slots and two sections that are interleaved with the bottom of the drawer. Once you have all three pieces separated, the while u-shaped handle piece, the plastic front panel, and the drawer itself, you can clean and dry them easily. To reassemble, first snap the while handle into place on the drawer, by lining up the top of the drawer to the while handle part first. The top of the handle fits over two plastic extensions on th top of the drawer, then swings down to cover the front sides of the drawer. Then reattach the bottom of the front plastic panel to the bottom of the drawer, interleaving the overlapping parts and snapping the tabs in place. Then snap the top of the front panel over the white handle at the top of the drawer, and you are done!
Dec 04, 2014 | Samsung Refrigerators
I need to reassemble a 1974 Fisher-Price toy cash register
Fisher Price cash register
I am assuming that you have removed the base to unjam the drawer, and a brown plastic lever fell out of the white assembly inside and you can't work out how to put it all back so it works. It took me three days to figure it out.
On the inside of the base is a long coiled spring. First hook this back over the end of the central drawer runner. Have a ruler or similar flat item handy to release it later.
Take the body of the cash register and insert the narrow end of the brown plastic lever through the white plastic assembly, until it engages with the handle mechanism. You will then feel resistance when turning the handle. There is a flat metal strip in the middle of the assembly. On the side of the brown lever is a small projecting peg. Put this behind the metal strip. Put the thicker end of the lever through the rectangular gap in the white assembly.
Place the drawer into the body of the cash register so that the back of it engages with the V shaped notch on the plastic lever.
Hold the drawer and body together with one hand and carefully lower them on to the base. While there is still a small gap under the drawer, insert the ruler to release the coiled spring. This will engage with the projection under the drawer.
Push everything together and replace the screws. Job done!
Nov 22, 2011 | Fisher Price Toys
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
How to completely clean the Crisper drawer
I don't know if you've already figured out how to remove the front panel on your refrigerator crisper bin, but here it is. Once the drawer is removed, pull back those clips on the top left & right of the front of the drawer.Just hold the side and pull back at the same time, then you can remove it. Once both side have been released you should be able to remove the clear plastic front and clean both pieces. I hope that is clear enough. Best of luck, unless of course you've already discovered the answer yourself.
Feb 21, 2010 | KitchenAid Refrigerators
Plastic handle Rival slow cooker model 38511 broken
The problem is the threads strip on the bolt and nut. I took these to Home Depot's specialty fastener section (the one with the drawers of stuff) and purchased a nylon bolt and nylon wing nut and solved the problem. I is easy to remove for cleaning and all is dishwasher safe.
Apr 03, 2009 | Crock Pots & Slow Cookers
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
Subzero model 532
Fernando is right! Now I will put it in girl terms. The lip of the drawer (lip is at back of the drawer) rests on a white plastic thing. But when you take the drawer out completely, the white plastic thing retracts and just looks like the back of the fridge. So when you go to put the drawer back in, you see nothing to put the lip on. So pull the white plastic thing (it looks like a white plastic rectangle about the size of an envelope) forward and then hook the lip onto it and gently pull the white "augur" (the thing that senses when it's time to make ice) down and slide the drawer back in. My son figured this out from reading Fernando's solution. What a relief! Our model is a 561.
Nov 03, 2007 | Sub-Zero 632 / S
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
