Question about Amana Refrigerators
Bottom freezer. How can I clean the condenser coils?
Posted by Rebecca Martin on
Andrew Taylor
    Top Expert:
  • Amana Master
  • 34,000 Answers
Vacuum cleaner, plus there are long brushes available
https://www.homedepot.ca/product/everbilt-universal-appliance-brush-set-2-pack-/1001420993
Posted on Sep 06, 2020
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: amana refrigerator
Sounds like it has either a bad compressor relay or if the brand name of the compressor is Tecumseh, it will need to be retrofit to a more reliable longer lasting Embraco compressor.
Posted on Jan 10, 2008
Techsim
James
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Mark Egan
  • 1214 Answers
SOURCE: anama bottom freezer
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 16, 2009
Anonymous
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
Anonymous
SOURCE: I have an Amana Refrigerator Model # ARB2202CC
where is the defrost timer located?
Posted on Jun 23, 2009
Amana bottow freezer wont completely
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Amana ABB1927DE Bottom Freezer...
Amana refrigerator, bottom freezer, refrigerator will not cool. No cold air coming thru vents
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
May 12, 2011 | Amana Refrigerators
Amana top fridge and bottom freezer both stopped working overnight, cleaned out all the dust and dirt from below
heatman101
Mar 19, 2011 | Amana ARB2217CSR Bottom Freezer...
Freezer on amana model arb8057csr quit working.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 29, 2010 | Amana ARB8057CSR Bottom Freezer...
Amana refridgerator temperature rising, especially freezer
heatman101
Oct 27, 2010 | Amana ABB2224D Bottom Freezer Refrigerator
I have a amana bc20tw fridge with bottom freezer that is keeping cold in the freezer and cool (43 degrees) in the fridge. I checked the coils in the freezer and there is no ice or major frost. Also, the...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Amana ABB1927DE Bottom Freezer...
Problem with the Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Clicking, buzzing, compressor too hot, thawed out freezer, fridge is semi cool
heatman101
Oct 10, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have an ARB2257CSL Amana bottom freezer refrigerator and the fridge portion just stopped cooling things down. The milk is warm but the freezer is working fine. We put the fridge all the way up and it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 09, 2010 | Amana ARB2257CSL Bottom Freezer...
I moved into a house a week ago and have noticed that the bottom freezer Amana refrigerator makes a grinding, humming, clicking noise constantly. I seems to be getting worse each day
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
heatman101
Aug 25, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Lights on not cooling
heatman101
rsjgfjf
Jun 25, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
108 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
