SOURCE: when video turned on audio chopping(unable to
Looks like a codec / CPU problem. Try lowering the frame rate and image quality, so that there is less data traffic to the CPU. Check also in Process Manager that the CPU isn't overloaded.
Hope this helps, have a nice day
Continuous blink once a
second, no pausing - No reply from the jungle IC301 (data
bus is busy, shorted to ground, or held high), IK video path is
defective.
One blink - not
used for the self-diagnosis
Two
blinks - B+ over current protection (OCP), unit goes to the
standby mode then displays the 2 blink fault. Could be a short in
the power
supply of any of the circuits.
Three blinks - B+
over voltage protection (OVP), unit goes to the standby mode then
displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
Four blinks - No
vertical Deflection (V STOP), Screen goes to a single horizontal
line then the video signal muted. Check IC1509, Q1505
Five blinks - AKB
circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on
the A board. In addition, unit could be in IK blanking, try turning
up screen slightly.
Six blinks - No
Horizontal (H STOP), no raster, goes to the blinking self-diagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
